Nagios XI -SQL: SQL Error [ndoutils] : Table './nagios/nagio
GacoAdmin110
Re: Nagios XI -SQL: SQL Error [ndoutils] : Table './nagios/n
Post by GacoAdmin110 »
I was able to free up about 17% more drive space by cleaning up temp/backups so my disk space is down to 62% used. Thanks much for the tips on cleanup!
That being said I still need to figure out how to expand the disk without killing the server.
Thnx
Mike
Did you power down the Nagios server before resizing the drive in VMWare?
If the server isn't shutdown, it could cause issues and may not boot after resizing.
GacoAdmin110
tgriep wrote:Did you power down the Nagios server before resizing the drive in VMWare?
I did not shut down the VM since normally you can just hot add disk...I will have to shut it down, add, and bring it back up...then retest.
Let us know once you get a chance to re-test with the VM being shut down, and if you need any further assistance.
