schedule downtime issue
Re: schedule downtime issue
I think I was able to replicate this issue, except it's showing a red box instead of green. I know the past bug was green, but should have been fixed in 5.2.3.
Can you see if you have the 'Has read-only access' box checked under your personal account? If so, uncheck it. It'll look like this - Let me know if that solves the issue or not.
I updated my profile. Still the same issue
To clarify, do you have read only checked or unchecked?
At the first time, it was unchecked.
I tried with both cases (checked and unchecked). same behavior.
Can you post your nagios.cfg for us to look at? As I wasn't able to replicate this so it's going to take some digging.
Also - what version of apache are you running?
apachectl -v
Here is apache version
Nagios config is attached.
# apachectl -v
Server version: Apache/2.2.15 (Unix)
Server built: Aug 24 2015 17:52:49
Is this a "local" or "AD/LDAP" auth type user? Are there any capital letters in the username?
For now, we are using only local accounts.
Attempt to schedule downtime from XI, then immediately run the following and post the output:
tail -40 /usr/local/nagios/var/nagios.log
