Thanks for the reply, I dont have the option under the CCM for "View Text config" I get all alerts set up by a monitoring wizard through to the contact unstedj - the issue is that no alerts are being generated by these specific monitors
Alerts not being Generated
trojanholdings
Re: Alerts not being Generated
Can you look again? You should have a "view text config" button that looks similar to a floppy disk. See this screenshot -lmiltchev wrote:Are you having issues with notifications not being sent to "unstedj" contact or some other contact, member of the "xxx_Alerting_Group" contacgroup? Please, show the config of this contact.
Core Configuration Manager->Contacts->View Text Config
If this is a "xi user" (not "contact only"), log in (or masquerade) as this user, click on the username in the upper right corner, then click on "Notification Preferences" and show a screenshot of this page.
trojanholdings
Thanks for that - I've managed to export this and attached is the text file
The "unstedj" contact seems to be properly defined. Can you verify that the "Receive alerts via email" check-box is selected under the "Notification Methods" for this user?
Can you show us the service definition of the failing "Check Webpoint Process" service?
Do the other members of the "xxx_Alerting_Group" contacgroup receive notifications about "Check Webpoint Process" service? Can you show us a screenshot of the "Notifications" report for the relevant timeperiod?
