Fortisnmp monitoring -help
batchen
Re: Fortisnmp monitoring -help
Post by batchen »
/etc/mrtg/mymrtg.cfg
are empty ,
as for /etc/mrtg/mrtg.cfg
and /etc/httpd/conf/mrtg.cfg i added the output in a txt file cause it didn't let me submit the message cause it was to long..
Regards,
etc_httpd_conf_mrtg.cfg.txt
(57.33 KiB) Downloaded 276 times
etc_mrtg_mrtg.cfg.txt
(57.65 KiB) Downloaded 298 times
In your /etc/mrtg/mrtg.cfg file, you have 2 WorkDir: options setup. Remove the incorrect entry and see if that helps.
batchen
Post by batchen »
what is the inncorect one?
i have thous :
WorkDir: /var/www/mrtg
WorkDir: /var/lib/mrtg
i supposed the correct one is
cause all the logs are there , i did the change and restart nagios.
now what?
is there another process to restart? and why are all the logs at /var/www/mrtg are created once (month ago) and never created again?
see the dates :
-rw-r--r--. 1 nagios nagios  1511 Jan 19 11:36 172.10.170.99_26-day.png
-rw-r--r--. 1 nagios nagios  6376 Jan 19 11:36 172.10.170.99_26.html
-rw-r--r--. 1 nagios nagios 48217 Jan 19 11:36 172.10.170.99_26.log
-rw-r--r--. 1 nagios nagios  1367 Jan 19 11:35 172.10.170.99_26-month.png
-rw-r--r--. 1 nagios nagios 48213 Jan 19 11:35 172.10.170.99_26.old
-rw-r--r--. 1 nagios nagios  1455 Jan 19 11:35 172.10.170.99_26-week.png
-rw-r--r--. 1 nagios nagios  1742 Jan 19 04:30 172.10.170.99_26-year.png
-rw-r--r--. 1 nagios nagios  1511 Jan 19 11:36 172.10.170.99_2-day.png
-rw-r--r--. 1 nagios nagios  6414 Jan 19 11:36 172.10.170.99_2.html
-rw-r--r--. 1 nagios nagios 48237 Jan 19 11:36 172.10.170.99_2.log
-rw-r--r--. 1 nagios nagios  1367 Jan 19 11:35 172.10.170.99_2-month.png
-rw-r--r--. 1 nagios nagios 48217 Jan 19 11:35 172.10.170.99_2.old
-rw-r--r--. 1 nagios nagios  1455 Jan 19 11:35 172.10.170.99_2-week.png
-rw-r--r--. 1 nagios nagios  1742 Jan 19 04:30 172.10.170.99_2-year.png
-rw-r--r--. 1 nagios nagios   350 Nov 12  2012 favicon.ico
-rw-r--r--. 1 nagios nagios  2772 Jan 19 15:36 index.html
MRTG data has expired (19659 minutes old)
Can you run the following and post the output?
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
ll /var/lock/mrtg/
batchen
Post by batchen »
tgriep wrote:Can you run the following and post the output?
ll /var/lock/mrtg/
this is the output:
root@localhost: ~#LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
root@localhost: ~#ll /var/lock/mrtg/
total 0
root@localhost: ~#
Post by Box293 »
ll /var/lock/mrtg/
this is the output:
total 0
root@localhost: ~#
Did the files get updated in /var/www/mrtg after running this?
batchen
Post by batchen »
ll /var/lock/mrtg/
this is the output:
total 0
root@localhost: ~#
nope, thay didnt :
root@localhost: objects#cd /var/www/mrtg/
root@localhost: mrtg#ll
total 288
Did the file in this folder get updated?
Run the following and post the output.
ls -l /var/lib/mrtg
batchen
Post by batchen »
tgriep wrote:Did the file in this folder get updated?
ls -l /var/lib/mrtg
it didnt update as well :
root@localhost: ~#ls -l /var/lib/mrtg
total 0
-rw-r--r--. 1 root root 0 Jan 19 13:20 mrtg.ok
Please run the following so we can get some debug information and post the output here.
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --debug=log,base
ps -ef
