ORACLE - (Return code of 127 is out of bounds - plugin may b
dlukinski
Re: ORACLE - (Return code of 127 is out of bounds - plugin m
Post by dlukinski »
tgriep wrote:There are issues with the Oracle 12.1 client that are causing the issue. The newer client doesn't have some of the required modules needed.
Remove the 12.1 Oracle Client and use the Oracle Client 11.2. That should fix the issue you are having.
went down to 11.2.0.4.0
Now getting this error:
CRITICAL - cannot connect to fihp-oradev06.konecranes.com :1532. ORA-12154: TNS:could not resolve the connect identifier specified (DBD ERROR: OCIServerAttach)
Can you show us the "tnsnames.ora" file?
Similar issue is described here:
http://www.perlmonks.org/?node_id=809180
dlukinski
Post by dlukinski »
lmiltchev wrote:Can you show us the "tnsnames.ora" file?
No such file in XI / get one from Oracle DB server?
Yes, it is located on the Oracle DB server.
dlukinski
Post by dlukinski »
Please keep this one open - still trying to obtain the file in question
hsmith
Agent Smith
Post by hsmith »
Sure.
Former Nagios Employee.
me.
dlukinski
Post by dlukinski »
hsmith wrote:Sure.
Here is the file (finally have one)
Thank you
Can you show us the exact command that you are running from the command line along with the output of it? What is the instance name that you are using in the command that is failing? (see below - the name is colored in red)
Example:
/usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --connect '10.102.33.221:1521/aprd' --username '<username>' --password '<password>' --mode connection-time --warning 1 --critical 5
dlukinski
Post by dlukinski »
lmiltchev wrote:Can you show us the exact command that you are running from the command line along with the output of it? What is the instance name that you are using in the command that is failing? (see below - the name is colored in red)
Example:
[root@cakc-nagxitest01 conf.d]# /usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --connect '10.x.x.237:1521/KCTCQA' --username 'nagiosxi' --password 'xxxxxxxx' --mode connection-time --warning 1 --critical 5
CRITICAL - cannot connect to 10.102.36.237:1521/KCTCQA. ORA-12543: TNS:destination host unreachable (DBD ERROR: OCIServerAttach)
hsmith
Agent Smith
Post by hsmith »
Can you try to telnet to this host:port?
me.
