Thank you for your feedback. I will try to work myself on this solution.
Instead of this solution, is it possible to copy the indexes and the snapshots we are interested in another NLS (quests' server) and then make them visible to this server web interface? If yes, can we then delete the parts we want to discard, for example delete all windows logs from all indexes?
Extract a query to another NLS instance
Re: Extract a query to another NLS instance
Definitely. What you'd do is set up backups using the following KB article: https://support.nagios.com/kb/article.p ... tegory=132Instead of this solution, is it possible to copy the indexes and the snapshots we are interested in another NLS (quests' server) and then make them visible to this server web interface?
After you set up your backups and have a full system backup, you're free to move those files to any cluster you'd like and restore them.
Yup! You can delete logs by using a query. Example:If yes, can we then delete the parts we want to discard, for example delete all windows logs from all indexes?
Delete all data of 'type:logsiwanttodelete' on a single index:
curl -XDELETE 'http://localhost:9200/logstash-2016.02.17/_query?q=type:logsiwanttodelete'Code: Select all
curl -XDELETE 'http://localhost:9200/_all/_query?q=type:logsiwanttodelete'
