NagiosXI Switch Monitoring
sdeshpande
Re: NagiosXI Switch Monitoring
Post by sdeshpande »
I have sent you a PM. Please let me know once you review it.
I noticed one thing -
[Thu Feb 04 13:31:38.828687 2016] [:error] [pid 3696] [client 10.120.219.192:57457] PHP Warning:  Unknown: Input variables exceeded 1000. To increase the limit change max_input_vars in php.ini. in Unknown on line 0, referer: http://nagiosxi.libremax.com/nagiosxi/config/monitoringwizard.php
Can you modify your php.ini and add one thing? It's usually located at /etc/php.ini. Look for the variable max_input_vars and change it from 1000 to 5000 (this may need to be higher depending on the stack, FYI). If the line doesn't exist, add this to the bottom of your file -
max_input_vars=5000
Once that's done, restart your httpd service,
service httpd restart
sdeshpande
I think that was it. You guys are the best.
We try :)
I'll be closing this thread now, but feel free to open another if you need anything in the future!
