Notifications for services not going out.
[email protected]
Re: Notifications for services not going out.
Correct all host notifications are being update but not emailing. Actually now the services notifications are working! Sort of it missed the last alert(in the notifications list) but did email it to me.
Will attach.
Here's the email
[email protected]
11:41 AM (10 minutes ago)
to reta
***** Nagios Monitor XI Alert *****
Notification Type: PROBLEM
Host: saucelabs.dev.meetearnest.com
State: DOWN
Address: 10.0.7.182
Info: CRITICAL - Socket timeout after 10 seconds
Date/Time: Thu Feb 4 11:41:18 PST 2016
Will attach.
Here's the email
[email protected]
to reta
State: DOWN
Address: 10.0.7.182
It looks like the only host with a contact defined is production-node-js-app6.Warning: Host 'admin.internal.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'agiloft.internal.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'client-payment-configuration.internal.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'loan-payment.internal.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'localhost' has no default contacts or contactgroups defined!
Warning: Host 'looker.internal.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'mobile.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'node-predict.internal.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'production-nodejs-app1' has no default contacts or contactgroups defined!
Warning: Host 'production-nodejs-app2' has no default contacts or contactgroups defined!
Warning: Host 'production-nodejs-app3' has no default contacts or contactgroups defined!
Warning: Host 'production-nodejs-app5' has no default contacts or contactgroups defined!
Warning: Host 'production-nodejs-app7' has no default contacts or contactgroups defined!
Warning: Host 'saucelabs.dev.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'vault.internal.meetearnest.com' has no default contacts or contactgroups defined!
Warning: Host 'vault.staging.meetearnest.com' has no default contacts or contactgroups defined!
define host {
host_name production-node-js-app6
use generic-host
alias production-node-js-app6
display_name Production API
address 10.0.7.233
check_command check_http!!!!!!!!
max_check_attempts 3
check_interval 2
retry_interval 1
active_checks_enabled 1
passive_checks_enabled 1
check_period 24x7
process_perf_data 1
retain_status_information 1
contacts reta
notification_interval 5
notification_period 24x7
notification_options d,u,r,
register 1
[email protected]
let me send u the updated profile
Can you rerun the verification, and post the output?
[email protected]
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Warning: Service 'Admin Service' on host 'admin.internal.meetearnest.com' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'Agiloft Service' on host 'agiloft.internal.meetearnest.com' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'Node Client Payment Configuration Serice' on host 'client-payment-configuration.internal.meetearnest.com' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'Node Loan Payment' on host 'loan-payment.internal.meetearnest.com' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'Looker Service' on host 'looker.internal.meetearnest.com' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'Node Mobile Service' on host 'mobile.meetearnest.com' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'Node Predict Service' on host 'node-predict.internal.meetearnest.com' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'SauceLabs SC Process' on host 'saucelabs.dev.meetearnest.com' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Checked 61 services.
Warning: Host 'production-nodejs-app4' has no default contacts or contactgroups defined!
Warning: Host 'production-nodejs-app8' has no default contacts or contactgroups defined!
Warning: Host 'production-nodejs-app9' has no default contacts or contactgroups defined!
Warning: Host 'production-task-runner-1' has no default contacts or contactgroups defined!
Warning: Host 'production-task-runner-2' has no default contacts or contactgroups defined!
Warning: Host 'production-task-runner-3' has no default contacts or contactgroups defined!
Warning: Host 'production-task-runner-5' has no default contacts or contactgroups defined!
Warning: Host 'production-task-runner-sched4' has no default contacts or contactgroups defined!
Checked 19 hosts.
Checked 5 host groups.
Checked 0 service groups.
Checked 3 contacts.
Checked 3 contact groups.
Checked 128 commands.
Checked 9 time periods.
Checked 0 host escalations.
Checked 19 hosts
Checked 0 host dependencies
Checked 9 timeperiods
Checking misc settings...
Total Warnings: 27
Total Errors: 0
[root@ip-172-16-3-76 var]#
These were defined
Nagios Core 4.1.1
License: GPL
Checking objects...
Checked 19 hosts.
Checked 3 contacts.
Checked 19 hosts
Total Warnings: 27
Total Errors: 0
These were defined
[email protected]
I updated using tool:
now
hecking objects...
Checked 19 hosts.
Checked 3 contacts.
Checked 19 hosts
Total Warnings: 8
Total Errors: 0
now
hecking objects...
Checked 19 hosts.
Checked 3 contacts.
Checked 19 hosts
Total Warnings: 8
Total Errors: 0
[email protected]
Now just email is not going out, I see the notifications logged in Nagios.
[email protected]
1454636055] SERVICE NOTIFICATION: reta;saucelabs.dev.meetearnest.com;Disk Usage;CRITICAL;xi_service_notification_handler;3
[1454636098] SERVICE ALERT: saucelabs.dev.meetearnest.com;Disk Usage;OK;HARD;3;DISK OK - free space: / 1065 MB (13% inode=43%):
[1454636098] SERVICE NOTIFICATION: nagiosadmin;saucelabs.dev.meetearnest.com;Disk Usage;OK;xi_service_notification_handler;DISK OK - free space: / 1065 MB (13% inode=43%):
[1454636098] SERVICE NOTIFICATION: reta;saucelabs.dev.meetearnest.com;Disk Usage;OK;xi_service_notification_handler;DISK OK - free space: / 1065 MB (13% inode=43%):
Seeing no email
Seeing no email
- Box293
- Too Basu
Run this command in an ssh session on your XI host:
Now go to the host or service object and from the Advanced tab force a notification to be sent. Please send us the full output from the ssh session.
tail -f /usr/local/nagiosxi/var/eventman.logAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
[email protected]
Nagios Log :
[1454696660] SERVICE ALERT: saucelabs.dev.meetearnest.com;Disk Usage;CRITICAL;SOFT;1;crit 1
[1454696667] SERVICE ALERT: saucelabs.dev.meetearnest.com;Disk Usage;CRITICAL;SOFT;2;2
[1454696673] SERVICE ALERT: saucelabs.dev.meetearnest.com;Disk Usage;CRITICAL;HARD;3;3
[1454696673] SERVICE NOTIFICATION: nagiosadmin;saucelabs.dev.meetearnest.com;Disk Usage;CRITICAL;xi_service_notification_handler;3
[1454696673] SERVICE NOTIFICATION: reta;saucelabs.dev.meetearnest.com;Disk Usage;CRITICAL;xi_service_notification_handler;3
[1454696705] SERVICE ALERT: saucelabs.dev.meetearnest.com;Disk Usage;OK;HARD;3;DISK OK - free space: / 1047 MB (13% inode=43%):
EVENT LOG:
User has mobile text notifications disabled...
PROCESS EVENT: ID=5369, SOURCE=2, TYPE=2, TIME=2016-02-05 10:24:34
*** GLOBAL HANDLER...
Array
[event_id] => 5369
[event_source] => 2
[event_type] => 2
[event_time] => 2016-02-05 10:24:34
[event_meta] => Array
[notification-type] => service
[contact] => reta
[contactemail] => [email protected]
[type] => PROBLEM
[escalated] => 0
[author] =>
[comments] =>
[host] => saucelabs.dev.meetearnest.com
[hostaddress] => 10.0.7.182
[hostalias] => Sauce Labs
[hostdisplayname] => Sauce Labs
[service] => Disk Usage
[hoststate] => UP
[hoststateid] => 0
[servicestate] => CRITICAL
[servicestateid] => 2
[lastservicestate] => CRITICAL
[lastservicestateid] => 2
[servicestatetype] => HARD
[currentattempt] => 3
[maxattempts] => 3
[serviceeventid] => 1020
[serviceproblemid] => 409
[serviceoutput] => 3
[longserviceoutput] =>
[datetime] => Fri Feb 5 10:24:33 PST 2016
[logging_enabled] => 1
*** GLOBAL HANDLER (snmptrapsender)...
Array
[event_id] => 5369
[event_source] => 2
[event_type] => 2
[contact] => reta
[type] => PROBLEM
[escalated] => 0
[author] =>
[comments] =>
[hoststate] => UP
[hoststateid] => 0
[maxattempts] => 3
Got XI user id for contact 'reta': 2
An email notification will be sent...
Email Notification Data:
Array
[from] => Nagios XI <root@localhost>
[to] => [email protected]
[subject] => PROBLEM Service Alert - saucelabs.dev.meetearnest.com/Disk Usage is CRITICAL
[high_priority] => 0
[message] => ***** Nagios XI Alert *****
Nagios has detected a problem with this service.
Service: Disk Usage
Address: 10.0.7.182
State: CRITICAL
Info:
3
Date/Time: 2016-02-05 10:24:35
Respond: http://172.16.3.76/nagiosxi/rr.php?uid= ... 2a8d18604d
Nagios URL: http://172.16.3.76/nagiosxi/
PROCESS EVENT: ID=5370, SOURCE=2, TYPE=1, TIME=2016-02-05 10:24:34
Array
[event_id] => 5370
[event_source] => 2
[event_type] => 1
[handler-type] => service
[hoststate] => UP
[hoststateid] => 0
[hosteventid] => 1016
[hostproblemid] => 0
[maxattempts] => 3
[servicedowntime] => 0
Array
[event_id] => 5370
[event_source] => 2
[event_type] => 1
[hoststate] => UP
[hoststateid] => 0
[maxattempts] => 3
SNMP TRAP SENDER NOT CONFIGURED!
.........tail: eventman.log: file truncated
PROCESSED 5 EVENTS
PROCESSED 3 EVENTS
EVENT LOG:
Array
[event_id] => 5369
[event_source] => 2
[event_type] => 2
[contact] => reta
[type] => PROBLEM
[escalated] => 0
[author] =>
[comments] =>
[hoststate] => UP
[hoststateid] => 0
[maxattempts] => 3
Array
[event_id] => 5369
[event_source] => 2
[event_type] => 2
[contact] => reta
[type] => PROBLEM
[escalated] => 0
[author] =>
[comments] =>
[hoststate] => UP
[hoststateid] => 0
[maxattempts] => 3
Array
Service: Disk Usage
Address: 10.0.7.182
State: CRITICAL
Info:
3
Array
[event_id] => 5370
[event_source] => 2
[event_type] => 1
[hoststate] => UP
[hoststateid] => 0
[maxattempts] => 3
Array
[event_id] => 5370
[event_source] => 2
[event_type] => 1
[hoststate] => UP
[hoststateid] => 0
[maxattempts] => 3
PROCESSED 5 EVENTS
PROCESSED 3 EVENTS
