Data not fully defined for storage /tmp : UNKNOWN
murawweh.daher
Re: Data not fully defined for storage /tmp : UNKNOWN
Post by murawweh.daher »
the below one for 1.3.2 with -e (exclude), i exclude NFS. there are few servers can't read /var or /export, so i exclude it and general service for /var or /export alone.
/usr/local/nagios/libexec/check_snmp_storage.pl -H server-name -C snmp-comm --v2c -e -m /arcdest1 --short=0,1 -w 90 -c 95 -f -q FixedDisk
OUTPUT: OK : (<90%) All selected storages | '/var/run'=0MB;56664;59812;0;62960 '/rocexp'=4845MB;46080;48640;0;51200 '/etc/mnttab'=0MB;0;0;0;0 '/rocra_directory'=880553MB;1127377;1190009;0;1252641 '/export'=0MB;135399;142921;0;150444 '/etc/svc/volatile'=0MB;56665;59813;0;62961 '/system/contract'=0MB;0;0;0;0 '/rocra'=14691MB;22565;23818;0;25072 '/apps'=20141MB;22555;23808;0;25061 '/vol'=0MB;0;0;0;0 '/internaldisk2'=243627MB;252032;266034;0;280036 '/export/home'=371MB;46080;48640;0;51200 '/'=46722MB;177449;187307;0;197166 '/etc/dfs/sharetab'=0MB;0;0;0;0 '/lib/libc.so.1'=46722MB;177449;187307;0;197166 '/proc'=0MB;0;0;0;0 '/system/object'=0MB;0;0;0;0 '/devices'=0MB;0;0;0;0 '/tmp'=0MB;56665;59813;0;62961
Regards,
Murawweh Daher
Can you also post the output for 1.3.3? I want to compare the specific results on your system.
murawweh.daher
/usr/local/nagios/libexec/check_snmp_storage_wizard.pl -H server-name -C snmp-comm --v2c -e -m /arcdest1 --short=0,1 -w 90 -c 95 -f -q FixedDisk
Use of uninitialized value in concatenation (.) or string at /usr/local/nagios/libexec/check_snmp_storage_wizard.pl line 547.
Use of uninitialized value in concatenation (.) or string at /usr/local/nagios/libexec/check_snmp_storage_wizard.pl line 548.
Use of uninitialized value in concatenation (.) or string at /usr/local/nagios/libexec/check_snmp_storage_wizard.pl line 549.
Regards,
Murawweh Daher
ssax
Dreams In Code
Post by ssax »
Please attach a copy of your 1.3.3 version so that I can compare it to mine, when I look at my code the line numbers do not match up to the errors, something may be different.
murawweh.daher
please find the attached.
Regards,
Murawweh Daher
ssax
Dreams In Code
Post by ssax »
It is identical to mine. Can you send me a copy of you 1.3.2 script, please?
Thank you
murawweh.daher
kindly find the attached.
Regards,
Murawweh Daher
ssax
Dreams In Code
Post by ssax »
Thank you
One of the other techs was saying that he though you had already resolved this with a script change, is that the case? If so, what did you change?
murawweh.daher
i used 1.3.2 instead of 1.3.3 and that solved my problem, but yesterday i test 1.3.3 again and insert (-o 5000) and worked. it seem the buffer size issue.
Regards,
Murawweh Daher
Are we good to mark this thread as resolved?
