Linux CPU and Hardware Statistic with Graphs
anguri.sudhakar
Re: Linux CPU and Hardware Statistic with Graphs
Post by anguri.sudhakar »
yes your right,
i need the values like second screen shot to show in multi-stacked graph .
Sudhakar Anguri
The numbers are the same, I believe the multi-stacked one is using actual numbers because it will have to compare with other items still, and these numbers could potentially change.
If you look at the 0's, 2500M is the same as 2500000000.
I can put in a feature request to have them use 2500M over 2500000000. Is that what you'd like?
anguri.sudhakar
Thank you ,Please put for the feature request ..
Got it. I've filed it, ID 7904.
Let me know if you have any other questions.
