Unable to get bandwidth utilization data from Cisco switch
brian.gamble
Re: Unable to get bandwidth utilization data from Cisco swit
Post by brian.gamble »
See results below
brian.gamble
ll /var/lib = drwxr-xr-x. 2 root root 4096 Oct 6 21:50 mrtg
ll /var/lib/mrtg = -rw-r--r-- 1 root root 105160 Oct 7 20:10 (ip_port).rrd
-rw-r--r--. 1 root root 0 Oct 7 20:10 mrtg.ok
nscott
Post by nscott »
Is it still saying rrd does not exist? If thats so then there is something screwy with the filenames. Otherwise, we'll have to check the SNMP method that MRTG is using the poll the switch router using snmpget.
Nicholas Scott
brian.gamble
It only shows that message for a few minutes, then the circle goes green but does not show the bandwidth in/out or graphs for that port.
brian.gamble
Attached a snapshot image of the issue. Again, the port image is orange and I get the message that the .rrd does not exist. After a few minutes, they turn from orange to green but do not show Mb/s in or out and no graph data on the ports.
nscott
Post by nscott »
brian,
Can you run
rrdtool fetch /var/lib/mrtg/<name of rrd file> AVERAGE
Do this on several of the RRDs, and post the output.
Nicholas Scott
brian.gamble
Ran the command against 3 seperate RRDs
lntinfo
Post by lntinfo »
Hi
I have the same problem, find the below rights. Need a soulution very urgent.
ll /var/lib
drwxr-xr-x. 2 root root 12288 Oct 10 13:05 mrtg
ll /var/lib/mrtg
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.102.xx.3_1.rrd
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.102.xx.3_4.rrd
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.102.xx.3_5.rrd
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.102.xx.4_1.rrd
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.102.xx.4_4.rrd
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.102.xx.4_5.rrd
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.70.xx_100.rrd
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.70.xx.xx_101.rrd
-rw-r--r-- 1 root root 105160 Oct 10 22:30 10.70xx.1_102.rrd
nscott
Post by nscott »
Ok guys, I'm gonna need you to try something. Can you edit the file /etc/cron.d/mrtg and put this on the end
--debug=time,base,snpo,log --logging /tmp/mrtg.log
So the entire line should look like this:
*/5 * * * * root LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok --debug=time,base,snpo,log --logging /tmp/mrtg.log
Then let it sit for a few minutes and check the logs. If you could bundle the logs and then them to email me at [email protected]. They contain senstive information so I suggest not posting them on the forums.
Nicholas Scott
lntinfo
Post by lntinfo »
done it, but I am not finding /tmp/mrtg.log file.
thx
