Networking for VMHost;CRITICAL;SOFT;1;ESX3 CRITICAL
Re: Networking for VMHost;CRITICAL;SOFT;1;ESX3 CRITICAL
Did you set the thresholds in XI as well? Is everything working as expected now?
Somebody help me, please.
Regards,
Marius
Regards,
Marius
I didn't set the thresholds in XI. How can I do that ?
Regards,
Marius
Regards,
Marius
- Box293
- Too Basu
In a previous post you provided screenshots of the services in CCM. It is here that you can adjust the arguments to include the thresholds.
Thank you! Now everything is working as expected.
I believe I have found a bug in check_esx3.pl, the bug shows up if we have a host with a vSwitch without physical NICs and we run /usr/local/nagios/libexec/check_esx3.pl -l NET -s nic
Can't use an undefined value as an ARRAY reference at /usr/local/nagios/libexec/check_esx3.pl line 803
You can consider the subject closed.
Best regards,
Marius
Best regards,
Marius
