Interesting Situation...
Re: Interesting Situation...
Sounds good, rkymtnhigh! Let us know if you get stuck on something. We will keep this topic open for the time being. Thank you!
rkymtnhigh
Post by rkymtnhigh »
I have managed to get both Nagios installs set up as hosts and reporting via NRPE basic system details.
My custom command seems to fail, so I went back to testing NRPE on each CentOS box.
When I run check_nrpe -H localhost now I'm getting
Error - Could not complete SSL handshake
Where as before I was getting:
NRPE v2.14
My checks are still coming back green, so maybe something isn't wrong? But my custom command returns nothing for output.
COMMAND: check_nrpe -H aws.ourdomain.com -c /usr/bin/perl customperlscript.pl -f /usr/local/nagios/libexec/argument.xml
OUTPUT:
Any help is greatly appreciated!
Testing nrpe locally as such:
/usr/local/nagios/libexec/check_nrpe -H localhost
should work if "127.0.0.1" is present on the "only_from" line... Can you show us the output of the following command?
cat /etc/xinetd.d/nrpe
Do the commands below work better?
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
or
/usr/local/nagios/libexec/check_nrpe -H <actual server's IP>
Also, you need to define your command in the nrpe.cfg or common.cfg, and call it this way:
./check_nrpe -H <remote IP> -c <command>
instead of calling the script directly.
Probably, you can set up a command in the "/usr/local/nagios/etc/nrpe/common.cfg" on the remote box like this:
command[myscript]=/usr/bin/perl /full/path/to/your/custom/script/customperlscript.pl -f /usr/local/nagios/libexec/argument.xml
Restart xinetd, so that changes can take effect:
service xinetd restart
Next, test it from Nagios XI:
/usr/local/nagios/libexec/check_nrpe -H <remote ip> -c myscript
rkymtnhigh
Thank you so much lmiltchev!
That was incredibly informative and helpful. I got my check up and running from the remote host.
Will dive into BPI and see if I run into any issues.
Thanks again!
He was a minute faster then me with his response.. Sounds good though! I'll leave this thread open, let us know if you have any further questions.
rkymtnhigh
You guys both helped tremendously. Thank you.
I've got the checks up and running, and I've created the BPI group with two test services that I can control its availability.
I've tripped both of them to Critical, and set my Warning threshold to 99 and Critical to 49. Yet I cannot make the group go into Warning or Critical!
Both services are showing in the group as critical, yet the group still shines green.
Perhaps I am misunderstanding something about thresholds and BPI.
What am I missing? Almost there!!
RMH
I am glad we are getting closer to solving the puzzle. :)
You will need to set up your BPI group with health thresholds like 51% (warning) and 1% (critical). This way, if one of the services is down, you will get an warning. If both are down - critical. Here's an example:
rkymtnhigh
It's weird. I've got my thresholds set like that, but the groups still says OK! I also don't get any information about the health status of the group like I see in your screenshot.
This is strange - perhaps you are using an older component. What is the version of Nagios XI and the Nagios BPI component that you are currently using?
rkymtnhigh
Nagios 5.2.2 and BPI 2.4.4
Thanks! This is the last piece of the puzzle!
