Change SNMP data
Re: Change SNMP data
Im not 100% sure how to do that, I will have to do some research and figure out how to write the script.
@jolson actually wrote it already. Here's quick instructions -
Create a file in the /usr/local/nagios/libexec/ directory
Paste this as the contents -
Run chown nagios:nagios yourfile (change yourfile to the name of the file you just created) - this will change the permissions to nagios:nagios.
Now, run chmod +x yourfile (change yourfile to the name of the file you just created) - this will make it executable.
Finally, run /usr/local/nagios/libexec/yourfile - this should be the result you're looking for. Please post the output once you run it for us to see.
Let us know if you run into any issues!
#!/bin/bash
output=$(/usr/local/nagios/libexec/check_snmp -H 10.2.50.251 -o 1.3.6.1.4.1.318.1.1.1.2.3.4.0 -C snmpstring -P 1 -l "Battery Actual Voltage" -u "V DC" -m powernet417.mib -w @682.5:882.5 -c @0:682.5)
exit=$?
if [ "$exit" == 0 ]
then
output2=$(echo "$output" | sed "s/./\.&/45")
output3=$(echo "$output2" | sed "s/./\.&/83")
echo "$output3"
exit 0
elif [ "$exit" == 1 ]
then
echo "$output"
exit 1
elif [ "$exit" == 2 ]
then
echo "$output"
exit 2
elif [ "$exit" == 3 ]
then
echo "$output"
exit 3
fiNow, run chmod +x yourfile (change yourfile to the name of the file you just created) - this will make it executable.
