XI Trial and MSSQL
thecountrylife08
Re: XI Trial and MSSQL
Post by thecountrylife08 »
Awesome, thank you! That semi-helped, it got me to this screen now which I don't think is an SQL Error because the server hasn't fired off an alert email yet
If you are not checking the master db, your db will not likely have the sysperfinfo table and so that check will fail.
This is somewhat expected, although not really mentioned. So with that, are you checking the master db or a separate one?
thecountrylife08
So I was definitely hitting the master db, but when the wizard runs it asks for an instance, me not thinking entered the instance name, removing that from the string corrected the issues! Thank you so much for all or your help!
Nice to see you were able to solve this!
Are we good to mark this thread as resolved then?
