Now we've run into a different problem, metrics doesn't try to generate anything.
edit. a collegue said that it was caused by the last update we performed.
I've attached our system profile.
Mod Edit: Files received and placed on shared drive. Profile deleted for privacy reasons.
Metrics - CPU & MEMORY usage not showing
Re: Metrics - CPU & MEMORY usage not showing
I was able to reproduce the blank metrics screen after upgrading to the latest Metrics Component.
The developers are looking at the issue and hopefully will fix the bug soon.
The other issue for Not Displaying the Memory Usage is because that component looks at the name of the command and some other parameters to determine if it should display it.
Since you created a custom command, it will not display it.
If you edit that service and put is back to the default settings, it should start to work as soon as the bug is fixed. Example below.
Ok, thank you, I'll test it out once there is a Metrics update available.
Your Welcome. I'll attach an older version of the Metrics component you can use in the mean time if you want until the bug gets fixed.
After update to 5.3.0 the Metrics component started working, so I've tried changing the command and it started working. Thank you, it is solved.
- Former Nagios Staff
Glad to hear it is resolved. I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
