Dell Servers are not reporting on Nagios Console
maverickmuggle
Re: Dell Servers are not reporting on Nagios Console
Post by maverickmuggle »
Dell PowerEdge Servers can be monitored using both in-band (SNMP or OMSA) or using iDRAC (SNMP or WS-MAN). However, the out-of-band monitoring is much more efficient than in-band as it doesn't rely on any agent running on OS. I would suggest using official Dell OpenManage Plug-In v2.0 for Nagios Core for monitoring Dell PE Servers. Other than Servers, it can also monitor Dell Chassis (M1000e, VRTX, FX2/FX2s) and Storage devices (Compellant, EqualLogic and PowerVault MD-Series). You can download the Dell OM plugin from following link:
http://en.community.dell.com/techcenter ... agios-core
Hope that helps,
Thanks.
Thanks @maverickmuggle!
@Mani1 - let us know if you have any further questions.
