CHECK_NRPE: Received 0 bytes from daemon
rambertnala
Re: CHECK_NRPE: Received 0 bytes from daemon
Post by rambertnala »
Hi friend.
I (0.4.3.143 2015-04-29) seem to be doing fine...
this is the oputput...
Regards
It is possible that the timeout is indeed the issue. If the script doesn't take more than a minute to run, try adding the following line to the nsclient.ini (under the default settings & nrpe sections):
timeout = 60
Restart the nsclient++ service and test your command again. Did this help?
I have a feeling it is the timeout, or your .bat file is failing somewhere. I setup a similar test, and it worked without issues.
In nsclient.ini -
restart_fw = scripts\custom\restart_fw.bat
In restart_fw.bat -
@echo off
net stop MpsSvc
timeout /t 10
net start MpsSvc
echo Firewall Restarted!
From Nagios -
[root@localhost libexec]# ./check_nrpe -H 192.168.5.47 -c restart_fw
The Windows Firewall service is stopping.
The Windows Firewall service was stopped successfully.
ERROR: Input redirection is not supported, exiting the process immediately.
The Windows Firewall service is starting.
The Windows Firewall service was started successfully.
Firewall Restarted!
