/usr/local/nagios/etc/nrpe.cfg
/etc/xinetd.d/nrpe
You will have to add the following line to your /etc/sudoers file on the remote server so the check has the ability to run the plugin.
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_init_serviceCan you login to the Nagios server, run the following and post the output?
/usr/local/nagios/libexec/check_nrpe -H s930l3085.rwe.com
