NRPE Failed to poll counter: PdhCollectQueryData
dlukinski
Re: NRPE Failed to poll counter: PdhCollectQueryData
Post by dlukinski »
rkennedy wrote:It looks to be lining up fine, (Network Interface(Intel(R) PRO/1000 MT Network Connection)) - I'm failing to see what isn't correlating as it should. Could you provide more information?
Name used by the service: (Network Interface(Intel[R] PRO_1000 MT Network Connection)
- works for the check with server name looking as follows:
Name used in the server: (Network Interface(Intel(R) PRO/1000 MT Network Connection)
- does not work if added to the check
Ah, I see now. When you look at the counter in Windows on the performance monitor , how does it appear?
dlukinski
Post by dlukinski »
rkennedy wrote:Ah, I see now. When you look at the counter in Windows on the performance monitor , how does it appear?
Thank you for the hint :-)
Please close this thread
