Could you PM a profile over for us to look at? I'd like to take a deeper look at your environment. (Admin -> System Profile -> Download Profile)
EDIT: Profile received.
Extremely slow load times for graphs after PHP upgrade
Re: Extremely slow load times for graphs after PHP upgrade
I noticed a few things when looking over your profile, which I'll point out here. Is there a reason you're running gnome on top of XI? This isn't reccomended at all.
Looks older, but regardless, something is spiking your load. -
SQL and Postgres both possibly not running - what happens if you start them? -
I see there are multiple NICs on the system, can you please run nslookup monitoring.atriacom.com from the XI system? Also, attach your /etc/hosts file.
How much resources do you have allocated to this machine? (Ram / CPU's)
[04-03-2016 13:09:47] NPCD: WARN: MAX load reached: load 10.640000/10.000000 at i=1
[04-03-2016 13:12:04] NPCD: WARN: MAX load reached: load 11.410000/10.000000 at i=0
[04-03-2016 13:12:19] NPCD: WARN: MAX load reached: load 10.150000/10.000000 at i=1
[04-04-2016 09:26:18] NPCD: WARN: MAX load reached: load 13.770000/10.000000 at i=0
[04-04-2016 09:26:33] NPCD: WARN: MAX load reached: load 11.520000/10.000000 at i=1
[Fri Apr 15 09:50:25.349252 2016] [:error] [pid 6282] [client 10.0.219.126:44365] PHP Warning: mysql_pconnect(): Link to server lost, unable to reconnect in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-mysql.inc.php on line 383, referer: http://monitoring.atriacom.com/nagiosxi///includes/page-home-main.php?&=
[Fri Apr 15 09:50:25.365107 2016] [:error] [pid 6283] [client 10.0.219.126:44364] PHP Warning: pg_pconnect(): PostgreSQL link lost, unable to reconnect in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-postgres64.inc.php on line 682, referer: http://monitoring.atriacom.com/nagiosxi///includes/page-home-main.php?&=
When I check my running services I see the following
an nslookup from my server returns
Gnome is running for the Linux challenged among the team to be able to access an RDP. If having it running is a problem I can strip it off.
specs of the VM are as follows
Is it likely sssd or winbind are causing some sort of problem?
[frack@monitoring ~]$ systemctl list-units | grep sql
postgresql.service loaded active running PostgreSQL database serverCode: Select all
[frack@monitoring ~]$ nslookup monitoring.atriacom.com
Server: 10.0.4.20
Address: 10.0.4.20#53
Address: 172.30.0.14specs of the VM are as follows
I will say that when I ran systemctl list-units I noticed a few failed services, a couple of which are likely due to a failed attempt to get LDAP authentication working.RAM: 16 GB
CPUS: 2 Sockets, 4 Cores
Single NIC card assigned in VM
[frack@monitoring ~]$ systemctl list-units | grep failed
â— fprintd.service loaded failed failed Fingerprint Authentication Daemon
â— rngd.service loaded failed failed Hardware RNG Entropy Gatherer Daemon
â— sssd.service loaded failed failed System Security Services Daemon
â— winbind.service loaded failed failed Samba Winbind DaemonRe: Extremely slow load times for graphs after PHP upgrade
All looks good from the outputs.
The upgrade of PHP might have done something. Can you open up a ticket so that we can get this moved into a remote?
