I sent the private message, and now the file is attached.
I'm so sorry with my mistake of the size file.
Regards.
Slow performance in nagios xi
Re: Slow performance in nagios xi
If you use the self-compiled module it may get overwritten and need to be re-implemented on upgrades.
I'm not seeing anything out of the ordinary from your profile.
I do see that your DB is offloaded, please check in /var/log/mysqld.log or /var/log/mariadb/mariadb.log for any crashed tables, that can impact performance quite a bit.
If your network speed/DB response speed is slow then it could also be causing this, every time you apply config it restarts nagios which will delete/update a lot of the objects in some of the nagios DB tables.
You might want to run mysqltuner on your DB to see what improvements can be made:
http://mysqltuner.com/
Also, run the top command and then apply configuration and see what is consuming all of the process at that time.
Thank you
Thank you
