Performance Graphs
tgfde
Re: Performance Graphs
Post by tgfde »
Is there a doc on how to install Graph Explorer?
Thanks.
We don't have a document but it is pretty straight forward process. Download the Graph Explorer component ( It requires Nagios XI 2011R1.3 or later).
In Nagios XI, click on "Admin" menu, then click on "Manage Components" under "System Extensions" from the left panel menu. Click on "Browse", locate the downloaded zip file, select it and click on "Upload Component" button. And that's it. It is installed. Go to "Home" and you will find the newly installed Graph Explorer under the "Performance Graphs" menu on the left.
Hope this helps.
tgfde
Post by tgfde »
Would an upgrade from 1.2 to 1.7 update the OS also?
I am currently running 1.2 on Cent OS 5.6 32 bit.
Frederick
It will not, but you should be OK with Cent OS 5.6 32 bit.
