【HELP】It can not be monitored
Re: 【HELP】It can not be monitored
On the Windows system in the nsc.ini if you are running the older version of NSClient or the nsclient.ini file, you need to add the IP address of the server that is failing and restart the NSClient service.
The setting is allowed_hosts or allowed hosts depending in the NSClient version.
Let us know if this fixed it for you.
Hello.
Sorry in clumsy English.
I'm sorry. It is not told well and.
It is itemized, but writes below it.
・C can be monitored from A.
・I cannot watch C from B.
・A and B are using the same cfg file.
・In B, it is synchronized with A.
・The monitoring object except C becomes the result same as A in B.
・I want to know why only C turns out different from A in B.
・Do A and B become the same result if they change which setting?
・Where is the place that you should investigate?
I'm sorry, but will you lend the power?
Thank you in advance.
- Box293
- Too Basu
On your windows server being monitored.
C:\Program Files\NSClient++\
In the file nsc.ini or nsclient.ini
There should be:
allowed_hosts=
or
allowed hosts =
This should be a comaseparated list of allowed hosts. 192.168.33.10,10.27.34.2
It should have the IP addresses of both Nagios Servers monitoring it.
There should be:
allowed_hosts=
or
allowed hosts =
Hello.
An IP address of A and B is entered in nsc.ini.
NSClient service of C also restarted, but a phenomenon doesn't change.
nsc.ini in C is attached.
ServerA IP=192.168.21.13
ServerB IP=192.168.3.6
Could you check it?
Could you check it?
NSC.ini- (11.98 KiB) Downloaded 264 times
- Box293
- Too Basu
The nsc.ini file looks correct.
Can you try the following command from both A and B Nagios servers and post back the results:
nmap -p 5666 ip_address_of_C
/usr/local/nagios/libexec/check_nrpe -H ip_address_of_CAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Hello.
There were no nmap commands in A and B.
Execution result by server A
/usr/local/nagios/libexec/check_nrpe -H 192.168.4.254
I (0.3.8.69 2010-05-19) seem to be doing fine...
Execution result by server B
CHECK_NRPE: Socket timeout after 10 seconds.
ServerC IP=192.168.4.254
Could you check it?
Could you check it?
- Box293
- Too Basu
You'll need to install nmap.
Then run the nmap commands.
yum install -y nmapAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Hello.
nmap was installed and carried out.
nmap -p 5666 192.168.4.254
Starting Nmap 4.11 ( http://www.insecure.org/nmap/ ) at 2016-04-27 15:49 JST
Interesting ports on 192.168.4.254:
PORT STATE SERVICE
5666/tcp open unknown
Nmap finished: 1 IP address (1 host up) scanned in 0.118 seconds
Starting Nmap 4.11 ( http://www.insecure.org/nmap/ ) at 2016-04-27 15:45 JST
Failed to find device eth0 which was referenced in /proc/net/route
nexthost: failed to determine route to 192.168.4.254
QUITTING!
Could you check it?
PORT STATE SERVICE
QUITTING!
Could you check it?
- Box293
- Too Basu
It appears that server B has no way of getting to 192.168.4.254.P3_25 wrote:Execution result by server B
QUITTING!
Perhaps a static route is required?
Hello.
The static route was set in neither B nor A.
Still is it necessary?
In addition, is there the place that you should doubt?
Could you check it?
Could you check it?
