PERL Scripts are not working V2
absarcompass
Re: PERL Scripts are not working V2
Post by absarcompass »
Hi guys,
sorry was away couldn't update you guys
the error messages mentioned above have these two plugins involve.
  • plugin_capture.pl
    check_database_table_locking.pl
can you please have a look what could have been an issue here
Post by Box293 »
Try:
yum install perl-Time-modules perl-MIME-Lite
absarcompass
Thanks Box293,
It has changed the erroneous output.
[root@nagiosxi libexec]# ./plugin_capture.pl /usr/local/nagios/libexec/check_database_table_locking.pl DATABASE
DBI connect('server=localhost;database=sql_jobs','sql_jobs',...) failed: Access denied for user 'sql_jobs'@'localhost' (using password: YES) at /usr/local/nagios/libexec/check_database_table_locking.pl line 271
Post by Box293 »
That no longer looks like a plugin issue but more of some sort of config required for the plugin.
You'll need to refer to the documentation on these plugins to find out what is required. If it's working on your old server, then it should just be a matter of looking at how the plugins run on the old server.
absarcompass
Hi Guys,
I am unable to locate the issue.
will try running the tcpdump on both the server to check what the plugin is passing or passing incorrectly.
Is your SQL server only allowing specific IP's? That could be the issue.
absarcompass
Yes, I can connect to server via isql and can run queries but same query is only working on old one, not in nagiosXI
although DB connections is established.
Had no luck with tcpdump as of yet, I only get database connection establishment and acknowledgement packets nothing of sort the values being passed within.
will dig more though
From the CLI can you authenticate to the remote SQL server? For example I can run this from the local XI machine and it works. Replace the values as needed for your DB.
mysql -uroot -pnagiosxi -hlocalhost
absarcompass
Hi Guys,
This issue was fixed, and my apologies for not updating this post.
I had to change the version in my freetds.conf to make scripts work.
you helpful guys can lock this thread now :D
Thanks for getting back to us!
