unable to monitor switch SNMP error
Re: unable to monitor switch SNMP error
It appears there is still an issue with SNMP running on the switch. Can you show us the output of show run from it? If not the whole output, anything that pertains to SNMP.
Can you post the snmp-server settings and the access-list from the switch?
What is the IP address of the XI server?
Take a look at this link and verify that the settings on the switch are correct.
http://www.cisco.com/c/en/us/td/docs/sw ... _0100.html
azam101
Post by azam101 »
Below is the snmp setting on the switch
Just to clarify, is the permit IP the one that Nagios XI uses?
azam101
Post by azam101 »
yes working now, not sure what was happening
Got it - are we good to mark this as resolved then?
azam101
Post by azam101 »
yes resolve this
