Still troubles with Webinject
dlukinski
Re: Still troubles with Webinject
Post by dlukinski »
ssax wrote:Everything that you posted is text, it doesn't mean visible text, the HTML markdown is considered text, you could use anything that the web server outputs that would let you know that you're on that page, I don't know enough about your application and what that page you are on does to tell you what you should select. I will say that you are limited to what the web app gives you.
Can you show a sanitized screenshot to show what the page actually does?
Is this a javascript application?
Let's close this one (realized by now limitations of WebInject and trying to substitute with SELENIUM)
Post by mcapra »
Closing this up
