NRPE check_cpu_stats unable to read, but other NRPE are fine
Re: NRPE check_cpu_stats unable to read, but other NRPE are
The issue is probably in the check_cpu_stats.sh script that you are using.
What shell do you have defined if that script?
If the path is wrong or that it is missing, that could cause it to fail.
