schedulereport.php not found
Re: schedulereport.php not found
Can you go to Admin > System Config > Manage System Config
Make sure the "Program URL" and "External URL" fields are the same URL and that the Nagios XI server can resolve that hostname.
Try that and see if that fixes the issue.
ciaranrh
Post by ciaranrh »
ssax wrote:What version of XI are you using? You can grab it from the bottom left hand side of the web interface.
Also, please go to Admin > Manage Components
- Find the Scheduled Reporting component and tell us the version number it shows next to it.
Thank you
Scheduled Reporting shows version 2.2.0
Can Nagios XI server resolve that hostname? What is the version of the Nagios XI that you are currently using?
ssax
Dreams In Code
Post by ssax »
Does this happen for all reports or only for this one? Have you tried deleting it and recreating it?
Please attach or PM the output of these commands:
echo "select * from xi_usermeta where keyname = 'scheduled_reports';" | mysql -uroot -pnagiosxi nagiosxi
echo "select * from xi_usermeta where keyname = 'scheduled_reports';" | psql nagiosxi nagiosxi
ciaranrh
Post by ciaranrh »
This was resolved, all that was needed was a restart of the Nagios server. Just so happened the restart was for another issue, but this turned out to be a happy surprise.
Regardless, thanks for the help!
Post by mcapra »
I'm glad you were able to find a solution! Closing this up
