LDAP Authentication
Re: LDAP Authentication
What type of LDAP server are you running, and what version of it? I'll try to replicate things on my end here.
Also, let's enable debugging to see if we can get any useful output.
sed -i 's/\/\/ Otherwise check authentication/ldap_set_option(NULL, LDAP_OPT_DEBUG_LEVEL, 7);/g' /usr/local/nagiosxi/html/includes/components/ldap_ad_integration/ldap_ad_integration.inc.php
Now, watch these log files -
tail -f /var/log/httpd/*error_log
Try to authenticate once again, and then please post the output from the tail.
To turn off the debugging, run the following -
sed -i 's/ldap_set_option(NULL, LDAP_OPT_DEBUG_LEVEL, 7);/\/\/ Otherwise check authentication/g' /usr/local/nagiosxi/html/includes/components/ldap_ad_integration/ldap_ad_integration.inc.php
