Cisco ASA 55xx - syslogs
matt.niarhakos
Re: Cisco ASA 55xx - syslogs
Post by matt.niarhakos »
Thanks. I added both. No dice.
hsmith
Agent Smith
Post by hsmith »
You replaced the syslog input entirely? What does it say in the logstash log now?
Former Nagios Employee.
me.
matt.niarhakos
Attached.
hsmith
Agent Smith
Post by hsmith »
Are you by chance trying to listen on 514 for any of your inputs?
me.
matt.niarhakos
These are the configured inputs. None listening on port 514.
It looks like it still is having issues listening -
{:timestamp=>"2016-06-30T10:54:41.137000-0700", :message=>"syslog listener died", :protocol=>:tcp, :address=>"0.0.0.0:5544", :exception=>#<Errno::EADDRINUSE: Address already in use - bind - Address already in use>, :backtrace=>["org/jruby/ext/socket/RubyTCPServer.java:118:in `initialize'", "org/jruby/RubyIO.java:853:in `new'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:152:in `tcp_listener'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:117:in `server'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:101:in `run'"], :level=>:warn}
What is the full output of ps -ef?
matt.niarhakos
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 Jun28 ?        00:00:01 /sbin/init
root         2     0  0 Jun28 ?        00:00:00 [kthreadd]
root         3     2  0 Jun28 ?        00:00:00 [migration/0]
root         4     2  0 Jun28 ?        00:00:07 [ksoftirqd/0]
root         5     2  0 Jun28 ?        00:00:00 [migration/0]
root         6     2  0 Jun28 ?        00:00:01 [watchdog/0]
root         7     2  0 Jun28 ?        00:10:07 [events/0]
root         8     2  0 Jun28 ?        00:00:00 [cgroup]
root         9     2  0 Jun28 ?        00:00:00 [khelper]
root        10     2  0 Jun28 ?        00:00:00 [netns]
root        11     2  0 Jun28 ?        00:00:00 [async/mgr]
root        12     2  0 Jun28 ?        00:00:00 [pm]
root        13     2  0 Jun28 ?        00:00:02 [sync_supers]
root        14     2  0 Jun28 ?        00:00:02 [bdi-default]
root        15     2  0 Jun28 ?        00:00:00 [kintegrityd/0]
root        16     2  0 Jun28 ?        00:00:30 [kblockd/0]
root        17     2  0 Jun28 ?        00:00:00 [kacpid]
root        18     2  0 Jun28 ?        00:00:00 [kacpi_notify]
root        19     2  0 Jun28 ?        00:00:00 [kacpi_hotplug]
root        20     2  0 Jun28 ?        00:00:00 [ata/0]
root        21     2  0 Jun28 ?        00:00:00 [ata_aux]
root        22     2  0 Jun28 ?        00:00:00 [ksuspend_usbd]
root        23     2  0 Jun28 ?        00:00:00 [khubd]
root        24     2  0 Jun28 ?        00:00:00 [kseriod]
root        25     2  0 Jun28 ?        00:00:00 [md/0]
root        26     2  0 Jun28 ?        00:00:00 [md_misc/0]
root        27     2  0 Jun28 ?        00:00:00 [khungtaskd]
root        28     2  0 Jun28 ?        00:01:29 [kswapd0]
root        29     2  0 Jun28 ?        00:00:00 [ksmd]
root        30     2  0 Jun28 ?        00:00:09 [khugepaged]
root        31     2  0 Jun28 ?        00:00:00 [aio/0]
root        32     2  0 Jun28 ?        00:00:00 [crypto/0]
root        37     2  0 Jun28 ?        00:00:00 [kthrotld/0]
root        38     2  0 Jun28 ?        00:00:00 [pciehpd]
root        40     2  0 Jun28 ?        00:00:00 [kpsmoused]
root        41     2  0 Jun28 ?        00:00:00 [usbhid_resumer]
root       172     2  0 Jun28 ?        00:00:00 [scsi_eh_0]
root       175     2  0 Jun28 ?        00:00:00 [scsi_eh_1]
root       194     2  0 Jun28 ?        00:00:15 [mpt_poll_0]
root       195     2  0 Jun28 ?        00:00:00 [mpt/0]
root       196     2  0 Jun28 ?        00:00:00 [scsi_eh_2]
root       284     2  0 Jun28 ?        00:01:49 [jbd2/sda1-8]
root       285     2  0 Jun28 ?        00:00:00 [ext4-dio-unwrit]
root       359     1  0 Jun28 ?        00:00:00 /sbin/udevd -d
root       528     2  0 Jun28 ?        00:00:10 [vmmemctl]
root       657   359  0 Jun28 ?        00:00:00 /sbin/udevd -d
root       660     2  0 Jun28 ?        00:00:00 [kstriped]
root       710     2  0 Jun28 ?        00:00:06 [kauditd]
root       738     2  0 Jun28 ?        00:03:07 [flush-8:0]
root       962     1  0 Jun28 ?        00:00:41 auditd
root       984     1  0 Jun28 ?        00:00:48 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
dbus      1001     1  0 Jun28 ?        00:00:00 dbus-daemon --system
root      1044     1  0 Jun28 ?        00:00:00 /usr/sbin/sshd
ntp       1055     1  0 Jun28 ?        00:00:02 ntpd -u ntp:ntp -p /var/run/ntpd.pid -g
nagios    1086     1 76 Jun28 ?        10-14:50:53 /usr/bin/java -Xms1002m -Xmx1002m -Djava.awt.headless=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+HeapDump
root      1107     1  0 Jun28 ?        00:00:29 sendmail: accepting connections
smmsp     1116     1  0 Jun28 ?        00:00:00 sendmail: Queue runner@01:00:00 for /var/spool/clientmqueue
root      1128     1  0 Jun28 ?        00:00:36 /usr/sbin/httpd
root      1141     1  0 Jun28 ?        00:00:13 crond
root      1214     1  0 Jun28 tty1     00:00:00 /sbin/mingetty /dev/tty1
root      1216     1  0 Jun28 tty2     00:00:00 /sbin/mingetty /dev/tty2
root      1218     1  0 Jun28 tty3     00:00:00 /sbin/mingetty /dev/tty3
root      1220     1  0 Jun28 tty4     00:00:00 /sbin/mingetty /dev/tty4
root      1222     1  0 Jun28 tty5     00:00:00 /sbin/mingetty /dev/tty5
root      1224     1  0 Jun28 tty6     00:00:00 /sbin/mingetty /dev/tty6
root      2774  1141  0 07:26 ?        00:00:00 CROND
nagios    2776  2774  0 07:26 ?        00:00:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1
nagios    2778  2776  0 07:26 ?        00:00:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller
root      2809  1141  0 07:27 ?        00:00:00 CROND
nagios    2811  2809  0 07:27 ?        00:00:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1
nagios    2812  2811  0 07:27 ?        00:00:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller
root      2842  1141  0 07:28 ?        00:00:00 CROND
root      2843  1141  0 07:28 ?        00:00:00 CROND
nagios    2844  2843  0 07:28 ?        00:00:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1
nagios    2845  2842  0 07:28 ?        00:00:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios    2846  2845  0 07:28 ?        00:00:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios    2847  2844  0 07:28 ?        00:00:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller
root      2870  1044  0 07:28 ?        00:00:00 sshd: root@pts/0
root      2872  2870  0 07:28 pts/0    00:00:00 -bash
root      2886  2872  0 07:28 pts/0    00:00:00 ps -ef
root     27243     1  0 Jun30 ?        00:00:00 runuser -s /bin/sh -c exec /usr/local/nagioslogserver/logstash/bin/logstash agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log  -w 4 nagios
nagios   27245 27243  0 Jun30 ?        01:28:38 /usr/bin/java -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx500m -Xss2048k -Djffi.boot.library.path=/usr/local/nagioslogserver/logstash
apache   29102  1128  0 Jul10 ?        00:00:28 /usr/sbin/httpd
apache   29103  1128  0 Jul10 ?        00:00:28 /usr/sbin/httpd
apache   29104  1128  0 Jul10 ?        00:00:28 /usr/sbin/httpd
apache   29105  1128  0 Jul10 ?        00:00:28 /usr/sbin/httpd
apache   29106  1128  0 Jul10 ?        00:00:28 /usr/sbin/httpd
apache   29107  1128  0 Jul10 ?        00:00:28 /usr/sbin/httpd
apache   29108  1128  0 Jul10 ?        00:00:27 /usr/sbin/httpd
apache   29109  1128  0 Jul10 ?        00:00:28 /usr/sbin/httpd
hsmith
Agent Smith
Post by hsmith »
Have you rebooted the entire server yet? Normally you should not need to do that on a Linux machine, but something is a little off here. Can you please try that and let me know what happens?
me.
matt.niarhakos
I actually restarted it this morning. No change.
hsmith
Agent Smith
Post by hsmith »
Are you behind a load balancer possibly?
me.
