ls -al /usr/local/nagios/var/
total 22524
drwxrwxr-x. 7 nagios nagios 4096 Jul 6 17:09 .
drwxr-xr-x. 9 root root 4096 Apr 23 2015 ..
drwxrwxr-x. 2 nagios nagios 24576 Jul 5 23:59 archives
drws------ 2 nagios nagios 4096 Jul 6 16:29 check_snmp
-rw-r--r-- 1 nagios nagios 4463 Jul 6 17:09 host-perfdata
-rw-r--r--. 1 nagios nagios 334 Jul 6 12:18 nagios.configtest
-rw-r--r-- 1 nagios nagios 6 Jul 6 12:18 nagios.lock
-rw-r--r-- 1 nagios nagios 329613 Jul 6 17:06 nagios.log
-rw-rw-r-- 1 nagios nagios 2020534 Jun 7 01:10 nagios.tmp0wn9h9
-rw-rw-r--. 1 nagios nagios 1493429 Nov 30 2015 nagios.tmpLRUcvC
-rw-rw-r-- 1 nagios nagios 1458405 Feb 1 01:22 nagios.tmpn3Rpv7
-rw-rw-r--. 1 nagios nagios 851554 Jun 27 2015 nagios.tmppLlwXn
-rw-r--r-- 1 nagios nagios 5 Jul 5 11:44 ndo2db.lock
-rw-r--r-- 1 nagios nagios 0 Jul 6 12:18 ndomod.tmp
srwxr-xr-x 1 nagios nagios 0 Jul 5 11:44 ndo.sock
-rw-r--r--. 1 nagios nagios 3388807 Jul 6 12:56 npcd.log
-rw-r--r--. 1 nagios nagios 1388234 Jul 6 12:18 objects.cache
-rw-r--r--. 1 nagios nagios 1388234 Jul 6 12:18 objects.precache
-rw-rw-r--. 1 nagios nagios 6494563 Jul 6 12:56 perfdata.log
-rw------- 1 nagios nagios 2070658 Jul 6 16:18 retention.dat
drwxrwsr-x. 2 nagios nagcmd 4096 Jul 6 12:18 rw
-rw-r--r-- 1 nagios nagios 16925 Jul 6 17:09 service-perfdata
drwxr-xr-x. 5 nagios nagios 4096 Apr 23 2015 spool
drwxr-xr-x. 2 nagios nagios 4096 Jul 6 17:09 stats
-rw-rw-r-- 1 nagios nagios 2060756 Jul 6 17:09 status.datHere are the folder permissions after it was created by the 'test check command':
total 22520
drwxrwxr-x. 7 nagios nagios 4096 Jul 6 17:19 .
drwx------ 2 apache apache 4096 Jul 6 17:13 check_snmpCode: Select all
ls -al /usr/local/nagios/libexec/check_snmp
-rwsrwxr-x. 1 apache nagios 251289 Apr 23 2015 /usr/local/nagios/libexec/check_snmp
