-p, --port=INTEGER
Optional port number (default: 12489)
-s, --secret=<password>
Service Monitoring with Special Characters
Re: Service Monitoring with Special Characters
The check_nt command also requires a password and the port used in the command line to work. Add those and try again.
- Box293
- Too Basu
This sounds like a bigger issue. Can you please post your nsc.ini or nsclientl.ini file from the NSClient++ directory on the Windows server.
In addition to the others,
Because of the dollar signs you will need to wrap it in single quotes:
You may also want to look at trying it as a user macro:
Edit /usr/local/nagios/etc/resource.cfg and add this at the bottom:
Then edit the service and change the $ARG2$ to:
Apply config and test, note that the test check command button won't work with user macros.
Let us know the results.
/usr/local/nagios/libexec/check_nt -H x.x.x.x -s 'SECRETPASS' -v SERVICESTATE -d SHOWALL -l 'MSSQL$MICROSOFT##WID'Edit /usr/local/nagios/etc/resource.cfg and add this at the bottom:
$USER9$=MSSQL$MICROSOFT##WIDCode: Select all
-d SHOWALL -l '$USER9$'Let us know the results.
