Oracle SQL Query Output In Nagios
CloudOps
Re: Oracle SQL Query Output In Nagios
Post by CloudOps »
rkennedy wrote:Can you show us a screenshot as an example?
Hi rkennedy,
u can see in the screenshot... its mentioned that output should return a number not a string.Also In database section, what i should enter?? default is system? can you explain me what i have to put? (highlighted with yellow)
That field you would put the name of the database you want / need to do the query against.
The wizard defaults to the System database and can be changed to whatever you need.
