The Availability Reports generation never ends
Re: The Availability Reports generation never ends
One thing you can try is to edit the /etc/hosts file and on the following line
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
Add your servers host name and FQDN also.
Then restart the Apache daemon by running
service httpd restart
Try running the report again and see if that helps.
The 504 error is pointing to a DNS resolving the IP address problem.
