nagios db crashed tables =(
Re: nagios db crashed tables =(
not yet. my number of objects is off and I have no hostgroups
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Did you check the mysqld.log on the offloaded server for more errors/crashed tables? It's possible that not all of the errors have been fixed?
Do you see the correct number of objects when you log in Nagios Core?
Try stopping/starting services on the Nagios XI server to see if this is going to resolve the issue:
http://ip address/nagiosCode: Select all
service nagios stop
service ndo2db stop
service ndo2db start
service nagios startBe sure to check out our Knowledgebase for helpful articles and solutions!
It may take a few minutes to build the NDO data, have the numbers increased?
ok lock it up im good. had to restart the nagios service after the numbers normalised
Proudly running:
Nagios Fusion
Nagios Fusion
Closing this per your request
