one click notification disabled nagios xi
Re: one click notification disabled nagios xi
You didn't answer two my questions, both of which I need answered -
Are you using notify-host-by-email or xi_host_notification_handler for notifications? Can you show us an example of one of the emails that came through?
Please address these.
Naveed
Post by Naveed »
I am using "xi_host_notification_handler" for notifications.
Email screenshot is attached.
I am seeing multiple nagios processes running on your server which could be causing the issue.
To fix that, login as root to the server, run the following commands
service nagios stop
killall -9 nagios
service nagios start
That should fix the issue for you.
Naveed
Post by Naveed »
Can you please explain this, although I have restarting my nagios server but could not understand. What had happened to it.
Thank you!
A stuck nagios process could be caused by a lot of things so it is hard to explain exactly why it happens.
A few that I have seen is that the system is busy and an Apply Configuration didn't finish in time which then spawns a new nagios process.
Naveed
Post by Naveed »
Great!
quite logical.
Thank you!
Post by mcapra »
Is it alright if we lock this thread and mark the issue as resolved?
Naveed
Post by Naveed »
yes, sure please.
Thank you!
