LDAP integration
Linuxlogger
Re: LDAP integration
Found the BasicLDAP.php file but it does not contain the referenced section. PM sent with file contents.
Linuxlogger
The BasicLDAP.php is contained below and I see no
"public function findBaseDn()
$namingContext = $this->getRootDse(array('namingcontexts'));
return $namingContext[0]['namingcontexts'][0];
#more /var/www/html/nagioslogserver/application/libraries/BasicLDAP.php
<?php @"SourceGuardian"; //v10.1.6 ?><?php // Copyright (c) 2008-2016 Nagios Enterprises, LLC. All rights reserved. ?><?php
if(!function_exists('sg_load')){$__v=phpversion();$__x=explode('.',$__v);$__v2=$__x[0].'.'.(int)$__x[1];$__u=strtolower(substr(php_uname(),0,3));$__ts=(@constant('PHP_ZTS') || @constan
t('ZEND_THREAD_SAFE')?'ts':'');$__f=$__f0='ixed.'.$__v2.$__ts.'.'.$__u;$__ff=$__ff0='ixed.'.$__v2.'.'.(int)$__x[2].$__ts.'.'.$__u;$__ed=@ini_get('extension_dir');$__e=$__e0=@realpath($
__ed);$__dl=function_exists('dl') && function_exists('file_exists') && @ini_get('enable_dl') && !@ini_get('safe_mode');if($__dl && $__e && version_compare($__v,'5.2.5','<') && function
_exists('getcwd') && function_exists('dirname')){$__d=$__d0=getcwd();if(@$__d[1]==':') {$__d=str_replace('\\','/',substr($__d,2));$__e=str_replace('\\','/',substr($__e,2));}$__e.=($__h
=str_repeat('/..',substr_count($__e,'/')));$__f='/ixed/'.$__f0;$__ff='/ixed/'.$__ff0;while(!file_exists($__e.$__d.$__ff) && !file_exists($__e.$__d.$__f) && strlen($__d)>1){$__d=dirname
($__d);}if(file_exists($__e.$__d.$__ff)) dl($__h.$__d.$__ff); else if(file_exists($__e.$__d.$__f)) dl($__h.$__d.$__f);}if(!function_exists('sg_load') && $__dl && $__e0){if(file_exists(
$__e0.'/'.$__ff0)) dl($__ff0); else if(file_exists($__e0.'/'.$__f0)) dl($__f0);}if(!function_exists('sg_load')){$__ixedurl='http://www.sourceguardian.com/loaders/download.php?php_v='.u
rlencode($__v).'&php_ts='.($__ts?'1':'0').'&php_is='.@constant('PHP_INT_SIZE').'&os_s='.urlencode(php_uname('s')).'&os_r='.urlencode(php_uname('r')).'&os_m='.urlencode(php_uname('m'));
$__sapi=php_sapi_name();if(!$__e0) $__e0=$__ed;if(function_exists('php_ini_loaded_file')) $__ini=php_ini_loaded_file(); else $__ini='php.ini';if((substr($__sapi,0,3)=='cgi')||($__sapi=
='cli')||($__sapi=='embed')){$__msg="\nPHP script '".__FILE__."' is protected by SourceGuardian and requires a SourceGuardian loader '".$__f0."' to be installed.\n\n1) Download the req
uired loader '".$__f0."' from the SourceGuardian site: ".$__ixedurl."\n2) Install the loader to ";if(isset($__d0)){$__msg.=$__d0.DIRECTORY_SEPARATOR.'ixed';}else{$__msg.=$__e0;if(!$__d
l){$__msg.="\n3) Edit ".$__ini." and add 'extension=".$__f0."' directive";}}$__msg.="\n\n";}else{$__msg="<html><body>PHP script '".__FILE__."' is protected by <a href=\"http://www.sour
ceguardian.com/\">SourceGuardian</a> and requires a SourceGuardian loader '".$__f0."' to be installed.<br><br>1) <a href=\"".$__ixedurl."\" target=\"_blank\">Click here</a> to download
the required '".$__f0."' loader from the SourceGuardian site<br>2) Install the loader to ";if(isset($__d0)){$__msg.=$__d0.DIRECTORY_SEPARATOR.'ixed';}else{$__msg.=$__e0;if(!$__dl){$__
msg.="<br>3) Edit ".$__ini." and add 'extension=".$__f0."' directive<br>4) Restart the web server";}}$msg.="</body></html>";}die($__msg);exit();}}return sg_load('52C4625FB82E51A9AAQAAA
AWAAAABHAAAACABAAAAAAAAAD/yt88Lix74mYuqruyoH8iJljDerPjNZr0misv9Sgtb+nOAWYZp2u3T/pYwMoT3qHb16nHr0yuw0bk6GMqZkitC5xU80kk2Xx/Tx0CSMWPTO7+k87nvZsLtFgRkIBKhY/vTd3/L3tT3rUh2dC+g5gujwUAAACwFQ
AAsnyeYU82LEjj0Lg2M1zxfqiuP+6B8w6Rv9Bx5bobTrfNimaEv2Bfa7qTy9Vf3K6SBcW4Sua1i4T3qBu8W7nS7Jzwvjj/qLBj52XI98mKz/NYTknsV6AghtMMngGJKAFOMBRRlhBPnTjDGjsVybcM8xE4EemxCm0989PZc3trRtnQ6U1X4J5QXj
PBQNiuC1ujDoSX0AHAMVgk+7vNxhCyGljbdwITUtTPcXpRcrVaDLDsZ0kWxseBNVWhp+9PIS6vi31U0G9FJYbMGgA2XvE5YvJgNcscmHJ8LA5zutTciHhLAfzQai8L4xuXV3uCQhJrL21GJ6cPJYOmZBBAejpjxh7v5JHZQV1fXjrRvwJPTPQZ6q
hdmdKwiVtxmJZmfhPeRB149dD9IQ0mcwhyGBHPKDeI6HTFMp7DvvBpQcFImfwxkUgo6lzKo2bxAZ+cWutSXriSG950qpZODiSVjt7RkstCwin/7ec4RY1FsPJJokZCHpatHtA7S9I2HgYFg97EFjly5weTNmPmtQffL7RfsYih+mUluBVYzrn37d
MD8UPl3t4/hJKrRBJ4MmuCwIF9+kN0EnsiwT2xGiaA3jc27bEGUk0TLiZlnHmyb8iMrLP4n6S5l8nOy+a7QkRThZwz1EaLPWglARRTvxohvEmmEY+Wu7AeAdlx3qK1KRnztLJ2C8p7MLoKd8KeplTB6dJGT96sUwmRFudbLns6UVYLfSZ2H7vqNu
RSLZ8kMV24mf3kQqk29W9g68+9nLXi2R2yKmGsY/RCAc7AtiUHmYbvnVToVJKA+JOsu1yusiL8KS62thp+W/njhpJI3Xz9Bhg1l38wZ5yasTva0DXm7DxMMNpebvApcvOOIlA+sLMmhxvjpgKJXCGn4t9QRX95KGqqLEUEG74qgIy5Cj/YusWS1j
tFPriL0Z7C5HyIKs8ggC1XFZjY4+Z2TqL2FwHXI03iwBypad8pOUBxN+xCkE+SSDunZXv6FmLhY+jTtLbAkbn4NmCjPy1RWQbirvOwp6pGHx2hzonKLlGarkMvWqeNoXVw0g2RU6UfQlDVA2QHT5mH8q0BZH9JjqnQT27Lqib6Y4gB4yZvPrhl6k
s+OUTLaW6uVgqwOupde1qLLAgFUGsNIYcnmthmWvrTNTtHKdG2SlCnvz/mVfd7Sln06Mn4sDGGnep+e6EyRkWuUIs8c9ukNO19PPvO03nbpUf2DizqzCmQ8qnmBKEmC0T2QoZy7Xjlpf5NLm5yUge7etXNmkN8D7mR4Ab5E0ClczYMNvjNcDrJ4V
K3UQA4m7/PQK+mSeW5KvbscEer6BV2ZdFm2atDWmlu8EzUc+nSNc9ZCv4skA4BxoY0ZPOC7VEzMcSPa77FxYD4IK+TOn8SwJhB+Ha5fqEkbI+E14ZzVd+8QdjLV9xkX3shQ7qx/f49TICOexz/ySZ3Rr2wJKnStmL0yMzuTAMwfA24qDKxg0K2zj
QcltlE1eq+WKv0oy6K6dNrIXv8Igczk6aHPh6DAGkO6tahKjC8iX/1oFKom72ILMDDQJXBEtRWVd2MbiqyxBCwe2agFGE3DJUaEoJj/MeSegqESh77I6citIMgbdleKGOn5saUdYfpHKiOPUObxdUblBL2KXlfkvvgkzW+NazneCq2z3ChjKtWAl
RYstP9srITizBPVG5d+2DA59XLIswliTMVL7ksqqx3lHMlLLX8V7pJRsOgs1KfQoebcbDnRlNyMX3VsxDJQAk0o1lCM78qnpAoAIqVbP4lgzdzgWMo5qnRk/HSUD5BsN0UmGRkAhuPYvp3oEQrgY0Tk8+6Za6X2MwaoVPC1Ci6m+YscMIHiMALSm
OJFJE4yZ3RkHZso/XbHAnFlxNJdW9Z5Y174fcbjue5vGdYgNxkopBSb25gxvU3qB9Q/VUmscP/z/iMBB+IV0YV7l0n1GJoKTB+Sl6gcL+KGgrNGw1TCBr8TA7RY6IwgJungGJy9v2ipkZhA1uHKWP6onOLTDSjwhbphERmisb8heC+5YEohu0xEO
IuqMlf5mUmsvPe3Fkp8pLJqon08NrEQaybb0Vof3m9Iz8kKSg8ZqT+v9HU77239eNUP4CJQ2EAKvnG1fXFyfzRhXTUr2qgu2QCqACeSpZZJ1rX+Aopw7TXQdIaQj6m0jt4+QyLa51+fVek8OrVVGmysanseboxerpWCV3JEIYMLLLV3FtA19o2Tt
NCz1SJqw7LJ3SMLKVrnJ3IEhc9aLH2Yr4OpXcujonoJasq2C/Qbij+1bLTlg/z+TVcbtv5NdjdHsy2q2HW2Z+sHTMO3SuFxo5yKVr9I1WMxBuhffe8+nEMq0TO7ilok9KSbJHH40qg6tTsUZNuFWxlzE0wKtY/8DvP7OoMUIOira8rkYsyvuo4Er
DoDK0xg+lQBwJMvSXVafOHmpXTsAt7sYYmcTYJocsf+gkaVL0FEjT1dQkeTSq0EhVMnH/xz1w4m5CPmlS+c7YoZE748mBE80VezUkAroMjYzBodgemhX+7O6L8LSuqo2ZL7SwETL8TE3PHDfjGCnpZMNul/EN/2HCWq4iC3LYSUuC8enQXHX9Y9v
1dQ56FksIAGeQS9ZWnD+Gn2PSnbILOONjWbvvN7eQkJNc//13mpBJzDYEAq7CQt3S9VgVYPSwZ/AfBY4C1infn9NKVH3uMhq55zllHlQFNDx86/+eQ1A2IT7c2f6r4F+Wm/s4NLtzW36apQgULhT3aMO4m2V405T/S0/xbupDA3JHcyeY7CNy/np
mBKZ4WPieJz6K7Y4agdCvOKY9rqGWnuDAjQuppzHDLVm1vcP8/+qDWzFhMlk+oHZGhPQVaa77AKncYJNIb7l/QCZxDfR/IG0S5iJYv0yzoRK5eA4Wr93W7pQ/uZQzhVUwzBmw2beS8fPUuGso9AiP8ikVC0kszVJ+Gals7Xlv2PWu+LV/cBrYMw8
CVo2+I3bXcMtPvGpiHUjHeeMJv2KO2A7CSn+LAjhoHurqqaN9UYZq+DvoodPnddyccLmSx+TN6FfYJQ69Rb9zeE8HsONC1Emhqfwelzd2rv6GZm4+o6N2d8HkFQmyR7cbHWUl4AWHqcgBEt0+8X7ETXE8SxAWO7ne/nAiSWxP/xkimZAD8MXhU+a
4xw4me7Q+bvfcyPOsiSYFKbJ0V2EWKuxLDwq1Kpf+yOZpysLdHf9bsBcAB4GrA7F5Xpe43DJtortCzWHQpQ1DZ27jWU/cqhiWgAt25sicnEleQbGSIIhqR7r0PFzazjURHd/1NUbyH8021E3AV/sHPmfcTjsq8JgaJAlHVsZPbIvdwHqPju/czMY
aoQ+n+L5aH1Peb9/y/vlfQ6MrgWGY6bLU3PQ6zaIIUhcCT5OpsVxiTi1uUT9WuEKWdY5bHOzjTApdOP0G/SsJS5GrnYzzMHLcYi6KYC95jYVR/xWBursJ8K9NKWCaWu9tKJE4S436WvXptgUm4C8iwU6OiWfayXF72J04CcbC3V9HVE0SP+btzXZ
TEO+4i92hQzI9Rklg/eW81AKqaf8ea0xwuVkL7IuyRZu+AYbEUOWUOFAwKA3mW1wmHGvmHxuURBdQZxlnZ3G7U6S1m2R0K7ZtUnvxvhI4RS5nD+4oWRu/5WB2noM63NPkrP1o+EvuNsFwn2F3b4q/cUSZF3KTx/P726yJ5QADRG7ZuOJUvlyq1Cy
KVMhNY+a4xKlnktSpqwHlHYr7E44ifZKzdUdq586PotARBznJSFHfJ4gdcheJNaRHF9gO51Ot0iHlJlZZdS4eFAitfCuFkABCCZAWeMPTpVOkNe3by8QJKInds7nBrbfBwbeA46VPMDURwrphVJQc6KBVfNUUMlHT3tVGLCCTJ/ITlBJ+mT12C50
+Q7Q0HxnXeB1pMsVKTYp4GKT84JPHMRZwG/omQN/OFKWm3szhfQ5TIizjDPGWPF6zJuT/EB8rv8Rd+gsHK4ihenb4+qSMRehU7WDXEk1/MVJGBTsWgHaCDLRZEgT13q6VZNb+Jonk7BDumrHkn8+deffAGsslfhV4pSSmiKsnaznok3DhSltkb3R
FlmzdVVMunJN06NGnQ6DeiVhgepogT2wQpmhDY+F/FGw9TrTm4dVNj4MGJOetB/XuZ1iJOE8pV/roCktaKSoJkQZfEukknjLfJSYlRJuqVSRDbZMUZp0Ob4DfecDui6+ICCO9pfg8ipssBKKb5gkfB1bvSL95x1Cl8/KC1owqMR2it3imo8nVlfe
yIEdlB14aPrFDF6S9yXsBeA0HC5eMy05HxqNTYJkuh+5H1GvJYRgHYLmx+zmm2Awfnpy140UZ8IC1L70ia0IsNNp1dju7/jMkhvcSgdD9dF5FqThdkhYQLf0ct1By+mQpnCL0IEv3oWGjTwSQo/+36tzEd5wuO8BlsFRmnWwBRSykfrkDOAlcEOs
vZYALiV8IFuOqAypgTny9xdkWKy9yJxAUW3mHKB31uNq4L8nldET6sV7F2yHDvpvD6ItSN2ZJSVQiGVNN0S1Kuz/cZ4+1IqsYmbPs8leDmwibOwNSOEn5e5+vto2JKBWLRG2TweuBxVrjBTWxgmaf83JYvUfc+PjYa3OCiNUDCDmwJxeYL/GZQsQ
GD29m6znqDGk50NCSyxSetRYVezqGCN+elrv/UGbW582H/gkENnwvWzZX/eMwm1SCL0Od70yJ3EO9QxRKXkjR8K5Yu0MWfDw2VQ12a87W9xp8nb4fD2duhHGW3q95EOvNdd0RNCjn7PjfgcFAvyVX0d7PZw+ie+Znu0FS7wclhmoUAZAfuSWHUsU
iFJyPhkWR5wIcYy66M9TPh1sQxNJsVRKtmmtkvHF9kmcB7BzZmU7QXUWbMja48zl6CvSdbCVusiGdhXbi+EWRDGN7/6wiXetmyWFNZ+NNo4sFxC2eScZt3wTHwmtRB3nDEjYHJjcz5C39Z1M713kjq/0rXSaVyrZDAB3XSlv0DdZ4qIP6a89bgGC
HCTEdAgqcLZKPHWQO5euaamFd8XMmCaG/Lmd2duX40PwVYjzHd02KcPPo/KVNPMo4Je7K1Ty4Yf4hEfz2jkEKd0gbYfe7P9Hgi6PTy2gc0foZL6nSr8VY3iAF1IRckXmczwUBM3Rzj1M2YSANryqWsbrF+pgcQLeSx96vN1mE14GeU18zbflJETX
rJf883H6GueAltq/K3l9rOSMfNlGgi6gKDXcZ7aRdI6jfR7WAFtmKK38WCHeTvAaiMPHQVYo8V4BVrQjPhBQlg5F1SEPQrFxHONP4bgO95rFuX91gFjAZZZr+guDwvsj9dltmo+AW+E1d5FCExOUiasDYSZEob1IkA5onU64u/SpVvRPbJoB3iGM
LWKUJG6RwjsVw8/6y7F3o4+f/UlCL5k9idH+DAggsqDo0RwEVL6WvB56t21vFgOONA7laKAA+Wmki8SbgrSXdBFc8oe71QUdsIQ75AtnAZ/hV/TJgjgskirX942pmM9BK/A8qFEV39haFsQSnMQvT5G5GArqpDmMXWJVfs+iEVlN9+9NL+LrOe2e
/rNQbZjgopDHm6680zZ2QJyQZ7ZE3tsJ+l0VOx9BuXmPxCnBTUAqHubjDrbuzmoYyH40pkv5K81GX0f3xFag5eCfiFYko4ddJA8bdH3HawvQCzVYDINkNfmrl+1k/d64z4pSag+tVEDz95uVIF0fCKv4wCNuh3KmeUxfTXwXJZQpp/Hb+Pn67HXb
JHNkKLtXr/MJvepJGRc4S+hMGVvXGd4xiAS7Sjf+p33PS6ANqV832ArubNzhlJZz3aHNEFcffPqemLVnrPCcXXw6qcrPQ5mymyYm82JpJcYDUP/R7ucSUzIeBgqKRx6ew3Y9PHzaXPOkrcSN7nhULL1JaWaVVUCeU/9DfVCS+q1TB50IG3/tMVDv
W4h+Wkivk1chgC9ojHFI5WNt4BKRV0KLtcvUCo6bRK/v0GzuVkwFGHLwii/Su1zjVp/JUTGmVFOryrzETh2qLxyK4csTQ4MS76uGjW0fjQ8GegrPZUaDV+5RAhwKdjysn0uzvqtX96m2tGGWvDQx0iyFKB0KbRFiXu0It8xMMBe6lI1kzjNKWJ4C
v4JioKlHfQdrZfHE5ZZ5xBbtGMXkmOELAaxkGzLoafQs6/QCwDs7o9aiHAvgb0BNxfXoDF4Xhv13DELy0hGsOWqCOp2o3kyfLvYJwzYaA1XzWoxiC0c+7Lx7ZoCPtCb+Fa2N2WszkuI3AXiKbdZCdOLIQ9stY0W3SlD3OjNmor+RL4jAdnzFIMHF
Reason: Added [code] [/code] tags to long output.
Linuxlogger
Not sure why my reply's are not getting through or showing up here but the BasicLDAP.php file did not contain the section mentioned.
Sorry about that, it looks like the files are encrypted, the developers will need to look into this.
Did you try this?
Did you try this?
One thing to try is to go up a level with the Base DN, so try o=ops,dc=mycompany,dc=com (also try just dc=mycompany,dc=com) instead of cn=users,o=ops,dc=mycompany,dc=com.
Linuxlogger
When I go up a level in the context my bind user is no longer able to log in.
Linuxlogger
My bind user resides in the same container with all my other users, if that makes any difference.
Ok, I've reached out to the developers so that they can look into this.
I believe that the LDAP code was written against OpenLDAP though, I'm not sure what is different in IBM Security Directory.
Linuxlogger
Since I am doing some LDAP logging with NLS I was able to get the exact LDAP DN for a user. I went into the "Create User" screen and selected LDAP user as type. I entered the full user DN but was still unable to add the LDAP user. I know the config is correct because of the LDAP logging but I am still confused as to why I cannot add an LDAP user to NLS.
Being an encrypted portion of the codebase, we're going to need to make some changes on our end and provide you with updated code to run. Unfortunately this means getting the developers involved which can take some time. We'll get back to you when we know more.
First, make a backup of your current files:
Replace these files with the ones I've attached (unzip them first):
Then go into the interface for importing users, after you type your credentials, click on the OU/container/group and then expand it as far as you can go. Please copy all of the text for the entire page and PM me the output.
Then when you're done you can revert the changes:
Thank you
cp /var/www/html/nagioslogserver/application/libraries/BasicLDAP.php /var/www/html/nagioslogserver/application/libraries/BasicLDAP.php.old
cp /var/www/html/nagioslogserver/application/helpers/ldap_ad_helper.php /var/www/html/nagioslogserver/application/helpers/ldap_ad_helper.php.old
/var/www/html/nagioslogserver/application/helpers/ldap_ad_helper.phpThen when you're done you can revert the changes:
cp /var/www/html/nagioslogserver/application/libraries/BasicLDAP.php.old /var/www/html/nagioslogserver/application/libraries/BasicLDAP.php
cp /var/www/html/nagioslogserver/application/helpers/ldap_ad_helper.php.old /var/www/html/nagioslogserver/application/helpers/ldap_ad_helper.php
