No errors in mysqld.logtgriep wrote:Maybe it is a corrupt MYSQL entry causing it.
Do you see any errors in the /var/log/mysqld.log file?
Can you create a new copy of that check and see if that works for you?
Also, run the following as root on the server and post the output here.Code: Select all
ps -ef --cols=300
ps -ef --cols=300 Mysql check results
Enter password:
mysql.columns_priv OK
mysql.db OK
mysql.event OK
mysql.func OK
mysql.general_log
Error : You can't use locks with log tables.
status : OK
mysql.help_category OK
mysql.help_keyword OK
mysql.help_relation OK
mysql.help_topic OK
mysql.host OK
mysql.ndb_binlog_index OK
mysql.plugin OK
mysql.proc OK
mysql.procs_priv OK
mysql.servers OK
mysql.slow_log
status : OK
mysql.tables_priv OK
mysql.time_zone OK
mysql.time_zone_leap_second OK
mysql.time_zone_name OK
mysql.time_zone_transition OK
mysql.time_zone_transition_type OK
mysql.user OK
nagios.nagios_acknowledgements OK
nagios.nagios_commands OK
nagios.nagios_commenthistory OK
nagios.nagios_comments OK
nagios.nagios_configfiles OK
nagios.nagios_configfilevariables OK
nagios.nagios_conninfo OK
nagios.nagios_contact_addresses OK
nagios.nagios_contact_notificationcommands OK
nagios.nagios_contactgroup_members OK
nagios.nagios_contactgroups OK
nagios.nagios_contactnotificationmethods OK
nagios.nagios_contactnotifications OK
nagios.nagios_contacts OK
nagios.nagios_contactstatus OK
nagios.nagios_customvariables OK
nagios.nagios_customvariablestatus OK
nagios.nagios_dbversion OK
nagios.nagios_downtimehistory OK
nagios.nagios_eventhandlers OK
nagios.nagios_externalcommands OK
nagios.nagios_flappinghistory OK
nagios.nagios_host_contactgroups OK
nagios.nagios_host_contacts OK
nagios.nagios_host_parenthosts OK
nagios.nagios_hostchecks OK
nagios.nagios_hostdependencies OK
nagios.nagios_hostescalation_contactgroups OK
nagios.nagios_hostescalation_contacts OK
nagios.nagios_hostescalations OK
nagios.nagios_hostgroup_members OK
nagios.nagios_hostgroups OK
nagios.nagios_hosts OK
nagios.nagios_hoststatus OK
nagios.nagios_instances OK
nagios.nagios_logentries OK
nagios.nagios_notifications OK
nagios.nagios_objects OK
nagios.nagios_processevents OK
nagios.nagios_programstatus OK
nagios.nagios_runtimevariables OK
nagios.nagios_scheduleddowntime OK
nagios.nagios_service_contactgroups OK
nagios.nagios_service_contacts OK
nagios.nagios_service_parentservices OK
nagios.nagios_servicechecks OK
nagios.nagios_servicedependencies OK
nagios.nagios_serviceescalation_contactgroups OK
nagios.nagios_serviceescalation_contacts OK
nagios.nagios_serviceescalations OK
nagios.nagios_servicegroup_members OK
nagios.nagios_servicegroups OK
nagios.nagios_services OK
nagios.nagios_servicestatus OK
nagios.nagios_statehistory OK
nagios.nagios_systemcommands OK
nagios.nagios_timedeventqueue OK
nagios.nagios_timedevents OK
nagios.nagios_timeperiod_timeranges OK
nagios.nagios_timeperiods OK
nagiosql.tbl_command OK
nagiosql.tbl_contact OK
nagiosql.tbl_contactgroup OK
nagiosql.tbl_contacttemplate OK
nagiosql.tbl_domain OK
nagiosql.tbl_host OK
nagiosql.tbl_hostdependency OK
nagiosql.tbl_hostescalation OK
nagiosql.tbl_hostextinfo OK
nagiosql.tbl_hostgroup OK
nagiosql.tbl_hosttemplate OK
nagiosql.tbl_info OK
nagiosql.tbl_lnkContactToCommandHost OK
nagiosql.tbl_lnkContactToCommandService OK
nagiosql.tbl_lnkContactToContactgroup OK
nagiosql.tbl_lnkContactToContacttemplate OK
nagiosql.tbl_lnkContactToVariabledefinition OK
nagiosql.tbl_lnkContactgroupToContact OK
nagiosql.tbl_lnkContactgroupToContactgroup OK
nagiosql.tbl_lnkContacttemplateToCommandHost OK
nagiosql.tbl_lnkContacttemplateToCommandService OK
nagiosql.tbl_lnkContacttemplateToContactgroup OK
nagiosql.tbl_lnkContacttemplateToContacttemplate OK
nagiosql.tbl_lnkContacttemplateToVariabledefinition OK
nagiosql.tbl_lnkHostToContact OK
nagiosql.tbl_lnkHostToContactgroup OK
nagiosql.tbl_lnkHostToHost OK
nagiosql.tbl_lnkHostToHostgroup OK
nagiosql.tbl_lnkHostToHosttemplate OK
nagiosql.tbl_lnkHostToVariabledefinition OK
nagiosql.tbl_lnkHostdependencyToHost_DH OK
nagiosql.tbl_lnkHostdependencyToHost_H OK
nagiosql.tbl_lnkHostdependencyToHostgroup_DH OK
nagiosql.tbl_lnkHostdependencyToHostgroup_H OK
nagiosql.tbl_lnkHostescalationToContact OK
nagiosql.tbl_lnkHostescalationToContactgroup OK
nagiosql.tbl_lnkHostescalationToHost OK
nagiosql.tbl_lnkHostescalationToHostgroup OK
nagiosql.tbl_lnkHostgroupToHost OK
nagiosql.tbl_lnkHostgroupToHostgroup OK
nagiosql.tbl_lnkHosttemplateToContact OK
nagiosql.tbl_lnkHosttemplateToContactgroup OK
nagiosql.tbl_lnkHosttemplateToHost OK
nagiosql.tbl_lnkHosttemplateToHostgroup OK
nagiosql.tbl_lnkHosttemplateToHosttemplate OK
nagiosql.tbl_lnkHosttemplateToVariabledefinition OK
nagiosql.tbl_lnkServiceToContact OK
nagiosql.tbl_lnkServiceToContactgroup OK
nagiosql.tbl_lnkServiceToHost OK
nagiosql.tbl_lnkServiceToHostgroup OK
nagiosql.tbl_lnkServiceToServicegroup OK
nagiosql.tbl_lnkServiceToServicetemplate OK
nagiosql.tbl_lnkServiceToVariabledefinition OK
nagiosql.tbl_lnkServicedependencyToHost_DH OK
nagiosql.tbl_lnkServicedependencyToHost_H OK
nagiosql.tbl_lnkServicedependencyToHostgroup_DH OK
nagiosql.tbl_lnkServicedependencyToHostgroup_H OK
nagiosql.tbl_lnkServicedependencyToService_DS OK
nagiosql.tbl_lnkServicedependencyToService_S OK
nagiosql.tbl_lnkServiceescalationToContact OK
nagiosql.tbl_lnkServiceescalationToContactgroup OK
nagiosql.tbl_lnkServiceescalationToHost OK
nagiosql.tbl_lnkServiceescalationToHostgroup OK
nagiosql.tbl_lnkServiceescalationToService OK
nagiosql.tbl_lnkServicegroupToService OK
nagiosql.tbl_lnkServicegroupToServicegroup OK
nagiosql.tbl_lnkServicetemplateToContact OK
nagiosql.tbl_lnkServicetemplateToContactgroup OK
nagiosql.tbl_lnkServicetemplateToHost OK
nagiosql.tbl_lnkServicetemplateToHostgroup OK
nagiosql.tbl_lnkServicetemplateToServicegroup OK
nagiosql.tbl_lnkServicetemplateToServicetemplate OK
nagiosql.tbl_lnkServicetemplateToVariabledefinition OK
nagiosql.tbl_lnkTimeperiodToTimeperiod OK
nagiosql.tbl_logbook OK
nagiosql.tbl_mainmenu OK
nagiosql.tbl_service OK
nagiosql.tbl_servicedependency OK
nagiosql.tbl_serviceescalation OK
nagiosql.tbl_serviceextinfo OK
nagiosql.tbl_servicegroup OK
nagiosql.tbl_servicetemplate OK
nagiosql.tbl_settings OK
nagiosql.tbl_submenu OK
nagiosql.tbl_timedefinition OK
nagiosql.tbl_timeperiod OK
nagiosql.tbl_user OK
nagiosql.tbl_variabledefinition OK
You have mail in /var/spool/mail/nagios
