Monitoring with SNMP
Re: Monitoring with SNMP
The filtered state output from the nmap command is pointing to a firewall / device that is blocking SNMP information to be polled by the Nagios server.
Can you verify that the firewall is allowing inbound connections to UDP port 161 and that there is not a device between the Nagios server and the host that could be blocking as well?
The nmap command should show an open state for it's output if the port is open.
ednaldojta
Iptables is inactive.
afflows imagem.
afflows imagem.
Edit the /etc/snmp/snmpd.conf file and replace it with the following.
Then restart the SNMP daemon by running
service snmpd restart
The above settings allow all hosts to access the SNMP Daemon on that host using version 2c and the community name of public.
Try that out and let us know if this fixes it for you.
com2sec notConfigUser default public
group notConfigGroup v1 notConfigUser
group notConfigGroup v2c notConfigUser
view systemview included .1.3.6.1.2.1.1
view systemview included .1.3.6.1.2.1.25
view systemview included interfaces.ifTable.ifEntry.ifAdminStatus
view systemview included .1 80
access notConfigGroup "" any noauth exact systemview none none
syslocation Unknown (edit /etc/snmp/snmpd.conf)
syscontact Root <root@localhost> (configure /etc/snmp/snmp.local.conf)
dontLogTCPWrappersConnects yes
ednaldojta
Friends got communication, however I think there is still something for me.
When set up to monitor via snmp for linux, it happens the following message.
Can you login to the Nagios server, run the following and post the output?
Can you run this command and post the /tmp/walk.txt file so we can review it?
If you changed the community string to something other that public, update the above commands.
/usr/local/nagios/libexec/check_snmp_storage_wizard.pl -H 10.10.60.52 -C public --v2c -m Physical -w 90 -c 99 -fCode: Select all
snmpwalk 10.10.60.52 -c public -v 2c >/tmp/walk.txtBe sure to check out our Knowledgebase for helpful articles and solutions!
ednaldojta
afflowers
The output of the snmpwalk shows that the remote system cannot be polled using SNMP so there is still something wrong with it.
Did you update the snmpd.conf file on that server with what I posted and restart the SNMP Daemon?
Is the IP address remote system you are trying to monitor 10.10.60.52?
What is the Operating System running on the remote server and it's version number?
ednaldojta
Yes, I updated! Follows the two arquivos.conf of the two machines.
OS versions of the machines are.
Nagios Server - CentOS - 6.7 (Final)
Remote Machine - CentOS 07/02/1511 (Core)
Iptables the two are disabled.
If the nmap command below still shows that the UDP port 161 is filtered, then something is blocking the connection to the remote system. Run this from the Nagios XI server.
If the port is open, the output of the nmap should look like this showing that the port is open.
The only thing I can think of is that there is something between the 2 systems blocking the SNMP Polls.
nmap 10.10.60.52 -sU -p 161Code: Select all
Nmap scan report for 192.168.112.130
Host is up (0.0055s latency).
PORT STATE SERVICE
161/udp open snmp
ednaldojta
Follows as requested. However iptables is Down.
Both in Nagios as the remote machine.
