Thank a lot mguthriemguthrie wrote:Ok, I have a feeling that this is being caused either by DB table corruption or a permissions issue somewhere on the system. Can you run the following procedure:
http://assets.nagios.com/downloads/nagi ... p#fixperms
And then also run the DB repair procedure:
http://assets.nagios.com/downloads/nagi ... irdatabase
Also make sure your system time is up to date, having that off can cause unpredictable results.
Ok will do that procedure..
Warm Rgds,
