Check_nrpe with Certificate Authentication
Re: Check_nrpe with Certificate Authentication
Post by Box293 »
I've thrown in a reply there to see if we can get some help on it, with direct links to how it works so it can be easy for him to understand.
ruffy01
Post by ruffy01 »
Thanks for that Box293.
Hopefully we can dig up a resolution of some sort :)
Cheers,
Ruffy.
Post by Box293 »
No worries, let's see if we get any response.
nozlaf
Post by nozlaf »
Based on your nsclient config your client would only accept connections via ssl, this could be confirmed by trying to connect without the -s option with check_nrpe
the reporting in the log file may differ based on the different client setups but if you cant connect to the 192.168.0.4 (server 2008 server) without the -s 1 option you should rest assured you have configured it properly
Also good to see a fellow Australian, Victorian and hopefully hawthorn supporter on here, maybe we should form a Nagios Austrlian user group Box293? maybe you could organise it in your spare time?
nozlaf
Post by nozlaf »
if you wanted to confirm 100% do a packet capture on the windows server and you should see the encrypted traffic
nozlaf wrote:Also good to see a fellow Australian, Victorian and hopefully hawthorn supporter on here, maybe we should form a Nagios Austrlian user group Box293? maybe you could organise it in your spare time?
NAUgios?
