Port checking difficulties
rdubya
Re: Port checking difficulties
Post by rdubya »
That's my point, there is no nagios user on that system to su to, and other plugins run as expected. Or maybe I'm misunderstanding your request.
What user is NRPE running as?
cat /usr/local/nagios/etc/nrpe.cfg | grep 'nrpe_'
rdubya
Post by rdubya »
Nagios server;
[root@engmon ~]# /usr/local/nagios/libexec/check_nrpe -H 10.177.177.220 -c check_users
USERS OK - 2 users currently logged in |users=2;5;10;0
[root@engmon ~]# /usr/local/nagios/libexec/check_nrpe -H 10.177.177.220 -c check_nexus_listen
NRPE: Unable to read output
NRPE client;
[root@nexusfirewall ~]# /usr/lib64/nagios/plugins/check_users -w 5 -c 10
[root@nexusfirewall ~]# /usr/lib64/nagios/plugins/check_listen_tcp_udp.sh -p 8070 -P tcp
OK -  Listening on 0.0.0.0:8070 (protocol: tcp)
I also created a nagios user;
-bash-4.1$ /usr/lib64/nagios/plugins/check_listen_tcp_udp.sh -p 8070 -P tcp
-bash-4.1$ /usr/lib64/nagios/plugins/check_users -w 5 -c 10
After creating the nagios user on the client, I returned to the the server and tried again;
While previewing before posting I saw rkennedy's reply. Interesting.
[root@nexusfirewall ~]# cat /etc/nagios/nrpe.cfg | grep 'nrpe_'
nrpe_user=nrpe
nrpe_group=nrpe
There is indeed an nrpe user, but it is set to nologin like everywhere else.
Could you try this?
su nrpe
rdubya
Post by rdubya »
Yes, once removing /sbin/nologin from the passwd entry.
[root@nexusfirewall etc]# su nrpe
No joy from the server side.
Hmm, what are the permissions on the file?
ls -al /usr/lib64/nagios/plugins/check_listen_tcp_udp.sh
rdubya
Post by rdubya »
It's root:root, but so is everything else in the plugin directory;
-rwxr-xr-x. 1 root root 5223 Aug 26 14:37 /usr/lib64/nagios/plugins/check_listen_tcp_udp.sh
ls -al /usr/lib64/nagios/plugins/check_users
-rwxr-xr-x. 1 root root 44360 Sep 11  2015 /usr/lib64/nagios/plugins/check_users
Some plugin have to run as the superuser account to function as they need to run as root to gather the required information.
Try running this to change the permissions for that plugin and see if it works.
chmod u+s /usr/lib64/nagios/plugins/check_listen_tcp_udp.sh
rdubya
Post by rdubya »
Same. What gets me is that this looks like an output formatting error. Is anybody here using this plugin successfully?
Strange, I just tested out that plugin on my system and it worked.
./check_nrpe -H 192.168.112.130 -c check_nexus_listen
OK -  Listening on 0.0.0.0:80 (protocol: tcp)
My remote system is a Centos7 server and here are the details on the permissions of the plugin and how it is defined in the nrpe.cfg file.
command[check_nexus_listen]=/usr/local/nagios/libexec/check_listen_tcp_udp.sh -p 80 -P tcp
-rwxr-xr-x 1 root nagios 5197 Sep 16 10:49 check_listen_tcp_udp.sh
The only difference it the group is set to nagios.
If changing that doesn't work, enable the debugging in the nrpe.cfg file on the remote server and see if you see any errors in the syslog files.
