Log Server does not create backups (Split topic)
Re: Log Server does not create backups (Split topic)
On both nodes, please run the following -
su nagios
touch /dir/to/your/mount/test
Then, show us the output on both machines. Did it work, or did you run into permission errors? It looks like root:root owns the directory s leading up to the share which could be problematic.
