how to install NRPE check plugin for Windows
Re: how to install NRPE check plugin for Windows
I believe the issue is caused by the spaces in the service name ("Teamcenter DispatcherClient V10000.1.0.41_20150609.00"). Is this the "Service name" or "Display name"? Can you right-click on the service, go to Properties, and see if there is an "alternative" name with no spaces? The plugin works, but escaping these spaces proves to be quite challenging...
For example, if I use a service with no spaces, the plugin works just fine:
[root@localhost ~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -t 300 -c check_winprocess -a '--filter "services eq CarboniteService"'
PROCESS OK - 1 process(es)|'processes'=1
Adding a second filter works, too.
[root@localhost ~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -t 300 -c check_winprocess -a '--filter "services eq CarboniteService" --filter "memusage gt 10000" --warn 0'
PROCESS WARNING - 1 process(es)|'processes'=1;0
[root@localhost ~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -t 300 -c check_winprocess -a '--filter "services eq CarboniteService" --filter "memusage gt 10000000" --warn 0'
PROCESS OK - 0 process(es)|'processes'=0;0
In the second command, I am getting "0 processes" as the memory usage of the CarboniteService is less than 10000000K.
The "--warn" flag also works.
[root@localhost ~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -t 300 -c check_winprocess -a '--filter "services eq CarboniteService" --filter "memusage gt 10000" --warn 1'
PROCESS OK - 1 process(es)|'processes'=1;1
In the second command, I get "PROCESS OK" instead of "PROCESS WARNING" as the number of processes doesn't exceed the warning threshold.
So far, so good. Now, when I try to run the same check against a service with spaces in the name, it fails.
[root@localhost ~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -t 300 -c check_winprocess -a '--filter "services eq Adobe Acrobat Update Service"'
As you can see, it shows "0 processes". I tried escaping the spaces, used single, and double quotes, etc. but I was not able to make this work. :(
However, when I use the "Service name", which doesn't contain spaces ("AdobeARMservice"), I get the expected output:
[root@localhost ~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -t 300 -c check_winprocess -a '--filter "services eq AdobeARMservice"'
caterpillartce
Post by caterpillartce »
Unfortunately that is both the service name and display name...
I can run the check_winprocess.exe with all those parameters in Windows command line on the server being monitored and get the desired result, which tells me check_winprocess.exe doesn't care about the spaces in the name (it recognizes the " around the filters)... See attached scrrenshot.
Is there a way for Nagios check_nrpe to work with it too?
Try the following.
1. Change your command in the nsclient.ini file to this:
check_winprocess=scripts\check_winprocess.exe --filter "services eq $ARG1$" --filter "memusage gt $ARG2$" --warn "$ARG3$"
2. Restart the NSClient++ service, so that changes can take effect.
3. Test it by running the following command from the CLI on the Nagios XI server:
/usr/local/nagios/libexec/check_nrpe -H <client ip> -c check_winprocess -a 'Teamcenter DispatcherClient V10000.1.0.41_20150609.00' 50 0
This *should* work. Well, it worked for me:
[root@localhost libexec]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_winprocess -a 'AMD External Events Utility' 100 0
[root@localhost libexec]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_winprocess -a 'AMD External Events Utility' 100 1
Hope this helps.
caterpillartce
Thanks for all the help. I found a way to make this kind of plugins work - use a wrapper bat file to put in the entire command line with all the parameters and call for the bat file in the nsclient.ini file instead.
Great! I am glad the issue has been resolved. I am locking this topic. If you have any more questions, please start a new thread.
