No notifications going out
cwscribner
Re: No notifications going out
Post by cwscribner »
# Contact configuration file
# Created by: Nagios QL Version 3.0.3
# Date:	      2011-11-03 09:46:10
# Version:    Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
define contact {
	contact_name                  		bhankers
	alias                         		Benjamin Hankerson
	contactgroups                 		admins
	host_notification_period      		bhankers_notification_times
	service_notification_period   		bhankers_notification_times
	host_notification_options     		d
	service_notification_options  		w,c
	email                         		[email protected]
	host_notifications_enabled    		1
	service_notifications_enabled 		1
	use                           		xi_contact_generic
define contact {
	contact_name                  		nagiosadmin
	alias                         		Nagios Admin
	host_notification_period      		nagiosadmin_notification_times
	service_notification_period   		nagiosadmin_notification_times
	host_notification_commands    		xi_host_notification_handler
	service_notification_commands 		xi_service_notification_handler
	use                           		xi_contact_generic,generic-contact
# END OF FILE
# Contact Group configuration file
define contactgroup {
	contactgroup_name             		admins
	alias                         		Nagios Administrators
	members                       		nagiosadmin
	contactgroup_name             		xi_contactgroup_all
	alias                         		All Contacts
# END OF FILE
cwscribner,
I didn't see anything "unusual" in the config files - they look fine. In my opinion, if nagios can send a test e-mail to one address and can't send it to another, most probably you will have to look at your network. Not sure what's going on.
cwscribner
Strange occurrence when testing this. We figured out that an IronPort appliance was blacklisting Nagios. I sent test notifications and the mobile text was received, but the email was not. Any ideas why that might happen?
I am not familiar with IronPort but I would guess that Nagios could've been blocked if considered to be a "high volume sender". I found this document, explaining how to configure IronPort's Safe/Block lists. Again, I am not familiar and I don't know if this will help.
http://admin.utep.edu/Portals/1623/How% ... onPort.pdf
cwscribner
One more thing...is there a default in nagios to use an event handler? I noticed in the templates that there is no event handler defined. Could that be the catch here?
mguthrie
Post by mguthrie »
I *think* that by default all state changes use the global event handler "xi_host_event_handler" and "xi_service_event_handler". However you can define specific event handlers at the template, host, and service level as well in addition to the global event handler.
cwscribner
I did some back tracking and it looks like the proper event handler is inherited from a previous template. I also ran another test by replaced the admin email with my own and I received notifications regularly again. After a brief discussion with the tech in charge of IronPort, I guess he's starting from scratch on the email blacklisting issue so hopefully I'll have better luck. Would it make a difference if the sending email is the same as the receiving email? For example, if the admin email is [email protected] and the alerts are getting sent from [email protected] to [email protected], will that cause an issue in alerting? I can send myself emails from my own email address so I wouldn't think this would cause a problem but I wanted to confirm with you first.
I don't think it would be an issue. On one of my test boxes I've got the same e-mail set for "to" and "from" and haven't had any issues.
