sudo /etc/init.d/logstash stop
Stopping Logstash Daemon: Errno::EBADF: Bad file descriptor - Bad file descriptor
each at org/jruby/RubyIO.java:3542
tcp_receiver at /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:175
tcp_listener at /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-input-syslog-0.1.6/lib/logstash/inputs/syslog.rb:161
[ OK ]
sudo /etc/init.d/logstash start
Starting Logstash Daemon: WARNING: Default JAVA_OPTS will be overridden by the JAVA_OPTS defined in the environment. Environment JAVA_OPTS are -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp
[ OK ]
I have similar issue, service starts and stops after sometime. What was the fix applied.
[ OK ]
[root@ip-10-1-252-201 ec2-user]# /usr/local/nagioslogserver/logstash/bin/logstash -f /usr/local/nagioslogserver/logstash/etc/conf.d
Sep 07, 2016 7:22:32 PM org.elasticsearch.plugins.PluginsService <init>
INFO: [2f526f36-8df4-4c76-b884-13a523776c3b] loaded [], sites []
Sep 07, 2016 7:22:33 PM org.elasticsearch.common.network.NetworkUtils <clinit>
WARNING: failed to resolve local host, fallback to loopback
java.net.UnknownHostException: ip-10-1-252-201.imcs.loca: ip-10-1-252-201.imcs.loca: unknown error
at java.net.InetAddress.getLocalHost(InetAddress.java:1505)
at org.elasticsearch.common.network.NetworkUtils.<clinit>(NetworkUtils.java:55)
at org.elasticsearch.transport.netty.NettyTransport.createClientBootstrap(NettyTransport.java:329)
at org.elasticsearch.transport.netty.NettyTransport.doStart(NettyTransport.java:224)
at org.elasticsearch.common.component.AbstractLifecycleComponent.start(AbstractLifecycleComponent.java:85)
at org.elasticsearch.transport.TransportService.doStart(TransportService.java:153)
at org.elasticsearch.client.transport.TransportClient.<init>(TransportClient.java:189)
at org.elasticsearch.client.transport.TransportClient.<init>(TransportClient.java:123)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at org.jruby.javasupport.JavaConstructor.newInstanceDirect(JavaConstructor.java:268)
at org.jruby.java.invokers.ConstructorInvoker.call(ConstructorInvoker.java:83)
at org.jruby.java.invokers.ConstructorInvoker.call(ConstructorInvoker.java:174)
at org.jruby.runtime.callsite.CachingCallSite.cacheAndCall(CachingCallSite.java:336)
at org.jruby.runtime.callsite.CachingCallSite.callBlock(CachingCallSite.java:179)
at org.jruby.runtime.callsite.CachingCallSite.call(CachingCallSite.java:183)
at org.jruby.java.proxies.ConcreteJavaProxy$InitializeMethod.call(ConcreteJavaProxy.java:56)
at org.jruby.RubyClass.newInstance(RubyClass.java:856)
at org.jruby.RubyClass$INVOKER$i$newInstance.call(RubyClass$INVOKER$i$newInstance.gen)
at org.jruby.internal.runtime.methods.JavaMethod$JavaMethodZeroOrOneOrNBlock.call(JavaMethod.java:301)
at org.jruby.java.proxies.ConcreteJavaProxy$NewMethod.call(ConcreteJavaProxy.java:155)
at org.jruby.runtime.callsite.CachingCallSite.cacheAndCall(CachingCallSite.java:326)
at org.jruby.runtime.callsite.CachingCallSite.call(CachingCallSite.java:170)
at org.jruby.ast.CallOneArgNode.interpret(CallOneArgNode.java:57)
at org.jruby.ast.LocalAsgnNode.interpret(LocalAsgnNode.java:123)
at org.jruby.ast.NewlineNode.interpret(NewlineNode.java:105)
at org.jruby.ast.BlockNode.interpret(BlockNode.java:71)
at org.jruby.evaluator.ASTInterpreter.INTERPRET_METHOD(ASTInterpreter.java:74)
at org.jruby.internal.runtime.methods.InterpretedMethod.call(InterpretedMethod.java:182)
at org.jruby.internal.runtime.methods.DefaultMethod.call(DefaultMethod.java:203)
at org.jruby.ast.FCallOneArgNode.interpret(FCallOneArgNode.java:36)
at org.jruby.ast.InstAsgnNode.interpret(InstAsgnNode.java:95)
at org.jruby.internal.runtime.methods.InterpretedMethod.call(InterpretedMethod.java:139)
at org.jruby.internal.runtime.methods.DefaultMethod.call(DefaultMethod.java:187)
at org.jruby.runtime.callsite.CachingCallSite.cacheAndCall(CachingCallSite.java:306)
at org.jruby.runtime.callsite.CachingCallSite.call(CachingCallSite.java:136)
at org.jruby.ast.VCallNode.interpret(VCallNode.java:88)
at org.jruby.internal.runtime.methods.InterpretedMethod.call(InterpretedMethod.java:204)
at org.jruby.internal.runtime.methods.DefaultMethod.call(DefaultMethod.java:211)
at org.jruby.evaluator.ASTInterpreter.INTERPRET_BLOCK(ASTInterpreter.java:112)
at org.jruby.runtime.Interpreted19Block.evalBlockBody(Interpreted19Block.java:206)
at org.jruby.runtime.Interpreted19Block.yield(Interpreted19Block.java:157)
at org.jruby.runtime.Block.yield(Block.java:142)
at org.jruby.RubyArray.collect(RubyArray.java:2399)
at org.jruby.RubyArray.map19(RubyArray.java:2412)
at org.jruby.RubyArray$INVOKER$i$0$0$map19.call(RubyArray$INVOKER$i$0$0$map19.gen)
at org.jruby.runtime.callsite.CachingCallSite.cacheAndCall(CachingCallSite.java:316)
at org.jruby.runtime.callsite.CachingCallSite.callBlock(CachingCallSite.java:145)
at org.jruby.runtime.callsite.CachingCallSite.callIter(CachingCallSite.java:154)
at org.jruby.ast.CallNoArgBlockNode.interpret(CallNoArgBlockNode.java:64)
at org.jruby.ast.IfNode.interpret(IfNode.java:118)
at org.jruby.internal.runtime.methods.InterpretedMethod.call(InterpretedMethod.java:112)
at org.jruby.internal.runtime.methods.DefaultMethod.call(DefaultMethod.java:169)
at org.jruby.runtime.callsite.CachingCallSite.cacheAndCall(CachingCallSite.java:286)
at org.jruby.runtime.callsite.CachingCallSite.callBlock(CachingCallSite.java:81)
at org.jruby.runtime.callsite.CachingCallSite.call(CachingCallSite.java:85)
at org.jruby.RubySymbol$1.yieldInner(RubySymbol.java:461)
at org.jruby.RubySymbol$1.yield(RubySymbol.java:481)
at org.jruby.RubyArray.eachCommon(RubyArray.java:1606)
at org.jruby.RubyArray.each(RubyArray.java:1613)
at org.jruby.RubyArray$INVOKER$i$0$0$each.call(RubyArray$INVOKER$i$0$0$each.gen)
at org.jruby.runtime.callsite.CachingCallSite.call(CachingCallSite.java:149)
at org.jruby.ast.CallNoArgBlockPassNode.interpret(CallNoArgBlockPassNode.java:53)
at org.jruby.ast.CallNoArgNode.interpret(CallNoArgNode.java:60)
at org.jruby.ast.RescueNode.executeBody(RescueNode.java:221)
at org.jruby.ast.RescueNode.interpret(RescueNode.java:116)
at org.jruby.ast.EnsureNode.interpret(EnsureNode.java:96)
at org.jruby.ast.ReturnNode.interpret(ReturnNode.java:92)
at org.jruby.runtime.Interpreted19Block.yield(Interpreted19Block.java:194)
at org.jruby.runtime.Interpreted19Block.call(Interpreted19Block.java:125)
at org.jruby.runtime.Block.call(Block.java:101)
at org.jruby.RubyProc.call(RubyProc.java:290)
at org.jruby.RubyProc.call19(RubyProc.java:271)
at org.jruby.RubyProc$INVOKER$i$0$0$call19.call(RubyProc$INVOKER$i$0$0$call19.gen)
at org.jruby.internal.runtime.methods.DynamicMethod.call(DynamicMethod.java:202)
at org.jruby.internal.runtime.methods.DynamicMethod.call(DynamicMethod.java:198)
at org.jruby.ast.CallSpecialArgNode.interpret(CallSpecialArgNode.java:65)
at org.jruby.ast.DAsgnNode.interpret(DAsgnNode.java:110)
at org.jruby.ast.BeginNode.interpret(BeginNode.java:83)
at org.jruby.RubyProc.call(RubyProc.java:228)
at org.jruby.internal.runtime.RubyRunnable.run(RubyRunnable.java:99)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.net.UnknownHostException: ip-10-1-252-201.imcs.loca: unknown error
at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:928)
at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1323)
at java.net.InetAddress.getLocalHost(InetAddress.java:1500)
... 169 more
