Nagios XI 5.2.9
Folder Watch 1.0.1
folder watch
Re: folder watch
Nagios XI 5.2.9
Folder watch 1.0.1
Folder watch 1.0.1
Re: folder watch
Open the "/usr/local/nagiosxi/html/includes/configwizards/folder_watch/folder_watch.inc.php" file in a text editor, and comment out lines 54 through 58. See example below:
Try running the wizard again. Now it should work.
Again, we are trying to help out, but XI is not officially supported on Ubuntu, at least not yet.
// Verify there were no errors running the plugin and that the perl module exists
55 //if (!empty($stderr) || strpos($stdout, "Can't locate") !== false) {
56 // $errors[] = _('It looks like the install script has failed. You may need to run the script as root:') . '<br>
57 // <b>sh /usr/local/nagiosxi/html/includes/configwizards/folder_watch/install.sh</b>';
58 //}Again, we are trying to help out, but XI is not officially supported on Ubuntu, at least not yet.
Re: folder watch
thanks lots lmiltchev.
with you about the "not supported" and deeply appreciate your help.
Commenting out the lines helped in configuring folder watch; but email/sms is not going out even when the "bad" files are there in the folder.
setting of folder_watch is in attached file.
Re: folder watch
When you navigate to Home -> Notifications, are they showing as sent? Are you using SMTP or sendmail?
