Upgrade and status staying yellow
Re: Upgrade and status staying yellow
Post by mcapra »
Very strange behavior for sure. I'm unsure if it's specific to the RSS feed though. It could be that it's failing to authenticate the session and by happenstance throwing an error on that path.
I would log all the XHRs and see if that provides a specific point of failure. In Chrome:
BanditBBS
Post by BanditBBS »
Came home and tried, got this on first attempt:
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
Failed to load resource: the server responded with a status of 404 (Not Found)
ZeroClipboard error of type "flash-deactivated": Flash is too outdated for your browser and/or is configured as click-to-activate
Then saw your reply and did that logging and nothing new logged.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
BanditBBS
Post by BanditBBS »
Scratch that, reloaded again and got the other error, so much more logged:
Navigated to http://naglog.itciss.com/nagioslogserver/
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/dashboard/do_update_check".
XHR finished loading: POST "http://naglog.itciss.com/nagioslogserver/api/system/status".
XHR finished loading: POST "http://naglog.itciss.com/nagioslogserver/api/user/get_dashboards".
XHR finished loading: POST "http://naglog.itciss.com/nagioslogserver/api/system/get_global_dashboards".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/dashboard/fetch_rss/marketing".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/jquery-1.10.1.min.js?ver=1.4.2&_=1473718767950".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/jquery-ui-1.10.3.custom.min.js?ver=1.4.2&_=1473718767951".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/jquery-ui-timepicker-addon.js?ver=1.4.2&_=1473718767952".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/bootstrap.min.js?ver=1.4.2&_=1473718767953".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/prettify.js?ver=1.4.2&_=1473718767954".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/bootstrap-progressbar.js?ver=1.4.2&_=1473718767955".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/ZeroClipboard.js?ver=1.4.2&_=1473718767956".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/main.js?ver=1.4.2&_=1473718767957".
XHR finished loading: GET "http://naglog.itciss.com/nagioslogserver/media/js/help.js?ver=1.4.2&_=1473718767958".
XHR finished loading: POST "http://naglog.itciss.com/nagioslogserver/auth/set_redirect_hash".
XHR finished loading: POST "http://naglog.itciss.com/nagioslogserver/api/check/get_queries?cb=1473718769255".
GET http://naglog.itciss.com/nagioslogserver/ZeroClipboard.swf?noCache=1473718776990 404 (Not Found)
I'm also still stuck on the fact it seems to have started when I updated to 1.4.2.
Post by mcapra »
Can you share the output of:
ls -al /var/www/html/nagioslogserver/www/media/js
Also try executing the following from the CLI of the NLS machine:
curl -XPUT 'http://localhost:9200/nagioslogserver/user/99' -d '{"username":"someuser","password":"c678bcf3b5138b9263a95c44d28097f22c2e02877193d2c25313478821d45c19","auth_type":"admin","email":"[email protected]","language":"default","apiaccess":"1","apikey":"1396e08757545557073844695e5b64caa0bd3ad3","created":"2015-01-23 10:00:00","created_by":0,"default_dashboard":"/dashboard/elasticsearch/default"}'
This will create a user named "someuser" with the password "nagiosls". See if logging in with this newly created account changes anything.
BanditBBS
Post by BanditBBS »
The new user acts the exact same.
Here is the output requested:
drwxrwxr-x 2 root apache   4096 Jan 20  2016 .
drwxrwxr-x 8 root apache   4096 Jan 20  2016 ..
-rw-rwxr-- 1 root apache  28756 Sep 12 08:43 bootstrap.min.js
-rw-rwxr-- 1 root apache   6069 Sep 12 08:43 bootstrap-progressbar.js
-rw-rwxr-- 1 root apache   2402 Sep 12 08:43 help.js
-rw-rwxr-- 1 root apache  93021 Sep 12 08:43 jquery-1.10.1.min.js
-rw-rwxr-- 1 root apache 228137 Sep 12 08:43 jquery-ui-1.10.3.custom.min.js
-rw-rwxr-- 1 root apache  74018 Sep 12 08:43 jquery-ui-timepicker-addon.js
-rw-rwxr-- 1 root apache    868 Sep 12 08:43 lang-css.js
-rw-rwxr-- 1 root apache   1802 Sep 12 08:43 lang-sql.js
-rw-rwxr-- 1 root apache  12638 Sep 12 08:43 main.js
-rw-rwxr-- 1 root apache  14551 Sep 12 08:43 prettify.js
-rw-rwxr-- 1 root apache  16682 Sep 12 08:43 run_prettify.js
-rw-rwxr-- 1 root apache  74328 Sep 12 08:43 ZeroClipboard.js
-rwxrwxr-x 1 root apache   4036 Sep 12 08:43 ZeroClipboard.swf
Post by mcapra »
Looking more into this issue, it's definitely related to the 1.4.2 upgrade. We changed a few things on the back-end to mitigate a XSS vulnerability which is likely what's giving you grief.
See this thread for a potential solution:
https://support.nagios.com/forum/viewto ... 37&t=39513
The answer from development on this topic was "NLS doesn't allow you to float freely between instances in a cluster" since the XSS patch. Enabling persistent connection was another possible solution.
BanditBBS
Post by BanditBBS »
That same fix he did fixed mine. You can close this, thanks!
