Logs not reporting again
Re: Logs not reporting again
Troy
[root@TGCS018 /]# curl -XGET 'http://localhost:9200/_cluster/health?pretty=true'
curl: (7) Failed connect to localhost:9200; Connection refused
[root@TGCS018 /]# curl -XGET 'http://localhost:9200/_cat/shards?v'
[root@TGCS018 /]#
[root@TGCS018 /]#
Can you verify that elasticsearch is able to start? Share the output of:
There are definitely some failed shards on this system which are probably impacting elasticsearch in a negative way. However, identifying and clearing those shards out is a bit difficult if the elasticsearch API is unavailable.
service elasticsearch restart
service elasticsearch status
ran them
[root@TGCS018 ~]# service elasticsearch restart
Restarting elasticsearch (via systemctl): [ OK ]
[root@TGCS018 ~]# service elasticsearch status
● elasticsearch.service - LSB: This service manages the elasticsearch daemon
Loaded: loaded (/etc/rc.d/init.d/elasticsearch)
Active: active (running) since Tue 2016-09-20 11:46:14 EDT; 15s ago
Docs: man:systemd-sysv-generator(8)
Process: 9067 ExecStop=/etc/rc.d/init.d/elasticsearch stop (code=exited, status=0/SUCCESS)
Process: 9074 ExecStart=/etc/rc.d/init.d/elasticsearch start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/elasticsearch.service
└─9094 java -Xms4111m -Xmx4111m -Djava.awt.headless=true -XX:+UseP...
Sep 20 11:46:14 TGCS018.our.network.tgcsnet.com systemd[1]: Starting LSB: Thi...
Sep 20 11:46:14 TGCS018.our.network.tgcsnet.com runuser[9085]: pam_unix(runus...
Sep 20 11:46:14 TGCS018.our.network.tgcsnet.com elasticsearch[9074]: Starting...
Sep 20 11:46:14 TGCS018.our.network.tgcsnet.com systemd[1]: Started LSB: This...
Hint: Some lines were ellipsized, use -l to show in full.
Still not able to access the site.
Apache problem maybe????????
After starting elasticsearch, did you run the check again? It's what is listening on port 9200.
The elasticsearch API actually uses Netty run within Java, not Apache. If you're saying that the CURL calls still fail after restarting elasticsearch, that doesn't have anything to do with Apache. If you're trying to access the Nagios Log Server GUI through a web browser and that is failing, that is probably an Apache issue.
For the former, please share the output of:
nmap -sT -O localhostFormer Nagios employee
Results of
[root@TGCS018 ~]# curl -XGET 'http://localhost:9200/_cluster/health?pretty=true'
"cluster_name" : "b46627e6-fb30-4cf0-b7ac-83e9d8af7481",
"status" : "red",
"timed_out" : false,
"number_of_nodes" : 1,
"number_of_data_nodes" : 1,
"active_primary_shards" : 125,
"active_shards" : 125,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 227,
"number_of_pending_tasks" : 0,
"number_of_in_flight_fetch" : 0
[root@TGCS018 ~]# curl -XGET 'http://localhost:9200/_cat/shards?v'
index shard prirep state docs store ip node
logstash-2016.09.17 4 p UNASSIGNED
logstash-2016.09.17 4 r UNASSIGNED
logstash-2016.09.17 0 p STARTED 27975 16.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.17 0 r UNASSIGNED
logstash-2016.09.17 3 p UNASSIGNED
logstash-2016.09.17 3 r UNASSIGNED
logstash-2016.09.17 1 p STARTED 27251 15.9mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.17 1 r UNASSIGNED
logstash-2016.09.17 2 p UNASSIGNED
logstash-2016.09.17 2 r UNASSIGNED
logstash-2016.09.13 2 p STARTED 187 58.4kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.13 2 r UNASSIGNED
logstash-2016.09.13 0 p STARTED 166 59.7kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.13 0 r UNASSIGNED
logstash-2016.09.13 3 p UNASSIGNED
logstash-2016.09.13 3 r UNASSIGNED
logstash-2016.09.13 1 p STARTED 183 63.8kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.13 1 r UNASSIGNED
logstash-2016.09.13 4 p STARTED 181 63.6kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.13 4 r UNASSIGNED
nagioslogserver 0 p UNASSIGNED
nagioslogserver 0 r UNASSIGNED
logstash-2016.09.15 2 p UNASSIGNED
logstash-2016.09.15 2 r UNASSIGNED
logstash-2016.09.15 0 p UNASSIGNED
logstash-2016.09.15 0 r UNASSIGNED
logstash-2016.09.15 3 p STARTED 47357 30.8mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.15 3 r UNASSIGNED
logstash-2016.09.15 1 p STARTED 47295 30.8mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.15 1 r UNASSIGNED
logstash-2016.09.15 4 p STARTED 49796 32.9mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.15 4 r UNASSIGNED
logstash-2016.09.12 4 p STARTED 76076 46mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.12 4 r UNASSIGNED
logstash-2016.09.12 0 p STARTED 77597 47.3mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.12 0 r UNASSIGNED
logstash-2016.09.12 3 p STARTED 77909 47.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.12 3 r UNASSIGNED
logstash-2016.09.12 1 p UNASSIGNED
logstash-2016.09.12 1 r UNASSIGNED
logstash-2016.09.12 2 p STARTED 77257 47.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.12 2 r UNASSIGNED
nagioslogserver_log 2 p UNASSIGNED
nagioslogserver_log 2 r UNASSIGNED
nagioslogserver_log 0 p UNASSIGNED
nagioslogserver_log 0 r UNASSIGNED
nagioslogserver_log 3 p STARTED 49619 4.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
nagioslogserver_log 3 r UNASSIGNED
nagioslogserver_log 1 p STARTED 49430 4.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
nagioslogserver_log 1 r UNASSIGNED
nagioslogserver_log 4 p UNASSIGNED
nagioslogserver_log 4 r UNASSIGNED
logstash-2016.08.25 4 p STARTED 578154 229.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.25 4 r UNASSIGNED
logstash-2016.08.25 0 p UNASSIGNED
logstash-2016.08.25 0 r UNASSIGNED
logstash-2016.08.25 3 p UNASSIGNED
logstash-2016.08.25 3 r UNASSIGNED
logstash-2016.08.25 1 p STARTED 578205 228.8mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.25 1 r UNASSIGNED
logstash-2016.08.25 2 p STARTED 578639 229.2mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.25 2 r UNASSIGNED
logstash-2016.08.26 2 p STARTED 512312 204.8mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.26 2 r UNASSIGNED
logstash-2016.08.26 0 p STARTED 512229 204.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.26 0 r UNASSIGNED
logstash-2016.08.26 3 p UNASSIGNED
logstash-2016.08.26 3 r UNASSIGNED
logstash-2016.08.26 1 p STARTED 511637 203.9mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.26 1 r UNASSIGNED
logstash-2016.08.26 4 p STARTED 511804 204.8mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.26 4 r UNASSIGNED
logstash-2016.08.23 2 p STARTED 574529 228.9mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.23 2 r UNASSIGNED
logstash-2016.08.23 0 p STARTED 574489 228.8mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.23 0 r UNASSIGNED
logstash-2016.08.23 3 p STARTED 574773 228.9mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.23 3 r UNASSIGNED
logstash-2016.08.23 1 p STARTED 574578 229.2mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.23 1 r UNASSIGNED
logstash-2016.08.23 4 p STARTED 574072 228.9mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.23 4 r UNASSIGNED
logstash-2016.08.24 2 p UNASSIGNED
logstash-2016.08.24 2 r UNASSIGNED
logstash-2016.08.24 0 p STARTED 580692 229.2mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.24 0 r UNASSIGNED
logstash-2016.08.24 3 p STARTED 580681 229.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.24 3 r UNASSIGNED
logstash-2016.08.24 1 p STARTED 580442 229mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.24 1 r UNASSIGNED
logstash-2016.08.24 4 p STARTED 580750 229.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.24 4 r UNASSIGNED
logstash-2016.08.29 2 p STARTED 814080 441.2mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.29 2 r UNASSIGNED
logstash-2016.08.29 0 p STARTED 814340 441.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.29 0 r UNASSIGNED
logstash-2016.08.29 3 p STARTED 814502 441.9mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.29 3 r UNASSIGNED
logstash-2016.08.29 1 p UNASSIGNED
logstash-2016.08.29 1 r UNASSIGNED
logstash-2016.08.29 4 p STARTED 814472 441.1mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.29 4 r UNASSIGNED
logstash-2016.08.27 4 p UNASSIGNED
logstash-2016.08.27 4 r UNASSIGNED
logstash-2016.08.27 0 p UNASSIGNED
logstash-2016.08.27 0 r UNASSIGNED
logstash-2016.08.27 3 p STARTED 655622 304.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.27 3 r UNASSIGNED
logstash-2016.08.27 1 p UNASSIGNED
logstash-2016.08.27 1 r UNASSIGNED
logstash-2016.08.27 2 p STARTED 654970 303.7mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.27 2 r UNASSIGNED
logstash-2016.08.28 2 p UNASSIGNED
logstash-2016.08.28 2 r UNASSIGNED
logstash-2016.08.28 0 p STARTED 810605 444.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.28 0 r UNASSIGNED
logstash-2016.08.28 3 p STARTED 810494 445.1mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.28 3 r UNASSIGNED
logstash-2016.08.28 1 p STARTED 810766 444.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.28 1 r UNASSIGNED
logstash-2016.08.28 4 p STARTED 811203 445.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.28 4 r UNASSIGNED
logstash-2016.08.21 2 p UNASSIGNED
logstash-2016.08.21 2 r UNASSIGNED
logstash-2016.08.21 0 p STARTED 512986 209.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.21 0 r UNASSIGNED
logstash-2016.08.21 3 p STARTED 513079 210.1mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.21 3 r UNASSIGNED
logstash-2016.08.21 1 p STARTED 513787 210mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.21 1 r UNASSIGNED
logstash-2016.08.21 4 p STARTED 513194 210mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.21 4 r UNASSIGNED
logstash-2016.08.22 2 p UNASSIGNED
logstash-2016.08.22 2 r UNASSIGNED
logstash-2016.08.22 0 p STARTED 570193 227.2mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.22 0 r UNASSIGNED
logstash-2016.08.22 3 p UNASSIGNED
logstash-2016.08.22 3 r UNASSIGNED
logstash-2016.08.22 1 p STARTED 570279 227.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.22 1 r UNASSIGNED
logstash-2016.08.22 4 p STARTED 570044 227.3mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.22 4 r UNASSIGNED
logstash-2016.08.20 4 p UNASSIGNED
logstash-2016.08.20 4 r UNASSIGNED
logstash-2016.08.20 0 p STARTED 4722 734.1kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.20 0 r UNASSIGNED
logstash-2016.08.20 3 p UNASSIGNED
logstash-2016.08.20 3 r UNASSIGNED
logstash-2016.08.20 1 p STARTED 4716 720.1kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.20 1 r UNASSIGNED
logstash-2016.08.20 2 p STARTED 4696 720.6kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.20 2 r UNASSIGNED
logstash-2016.09.06 2 p UNASSIGNED
logstash-2016.09.06 2 r UNASSIGNED
logstash-2016.09.06 0 p STARTED 1361952 597.3mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.06 0 r UNASSIGNED
logstash-2016.09.06 3 p STARTED 1414843 620mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.06 3 r UNASSIGNED
logstash-2016.09.06 1 p STARTED 1397446 613.7mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.06 1 r UNASSIGNED
logstash-2016.09.06 4 p UNASSIGNED
logstash-2016.09.06 4 r UNASSIGNED
logstash-2016.09.04 2 p STARTED 3991661 1.5gb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.04 2 r UNASSIGNED
logstash-2016.09.04 0 p STARTED 3990850 1.5gb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.04 0 r UNASSIGNED
logstash-2016.09.04 3 p STARTED 3991300 1.5gb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.04 3 r UNASSIGNED
logstash-2016.09.04 1 p STARTED 3991132 1.5gb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.04 1 r UNASSIGNED
logstash-2016.09.04 4 p STARTED 3991961 1.5gb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.04 4 r UNASSIGNED
logstash-2016.09.05 4 p UNASSIGNED
logstash-2016.09.05 4 r UNASSIGNED
logstash-2016.09.05 0 p UNASSIGNED
logstash-2016.09.05 0 r UNASSIGNED
logstash-2016.09.05 3 p STARTED 5050593 1.9gb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.05 3 r UNASSIGNED
logstash-2016.09.05 1 p STARTED 5050647 1.9gb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.05 1 r UNASSIGNED
logstash-2016.09.05 2 p STARTED 5051682 1.9gb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.05 2 r UNASSIGNED
logstash-2016.09.02 4 p STARTED 808011 440.3mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.02 4 r UNASSIGNED
logstash-2016.09.02 0 p STARTED 807463 440.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.02 0 r UNASSIGNED
logstash-2016.09.02 3 p UNASSIGNED
logstash-2016.09.02 3 r UNASSIGNED
logstash-2016.09.02 1 p STARTED 808367 441mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.02 1 r UNASSIGNED
logstash-2016.09.02 2 p STARTED 807572 440.7mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.02 2 r UNASSIGNED
logstash-2016.09.03 4 p STARTED 1818742 836.7mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.03 4 r UNASSIGNED
logstash-2016.09.03 0 p STARTED 1818667 837.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.03 0 r UNASSIGNED
logstash-2016.09.03 3 p STARTED 1819065 837.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.03 3 r UNASSIGNED
logstash-2016.09.03 1 p STARTED 1819099 837.7mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.03 1 r UNASSIGNED
logstash-2016.09.03 2 p STARTED 1818826 837.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.03 2 r UNASSIGNED
logstash-2016.09.01 4 p STARTED 802032 440.2mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.01 4 r UNASSIGNED
logstash-2016.09.01 0 p UNASSIGNED
logstash-2016.09.01 0 r UNASSIGNED
logstash-2016.09.01 3 p STARTED 802307 440.9mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.01 3 r UNASSIGNED
logstash-2016.09.01 1 p UNASSIGNED
logstash-2016.09.01 1 r UNASSIGNED
logstash-2016.09.01 2 p STARTED 802667 440.8mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.09.01 2 r UNASSIGNED
logstash-2016.08.09 2 p UNASSIGNED
logstash-2016.08.09 2 r UNASSIGNED
logstash-2016.08.09 0 p STARTED 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.09 0 r UNASSIGNED
logstash-2016.08.09 3 p STARTED 52 32kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.09 3 r UNASSIGNED
logstash-2016.08.09 1 p STARTED 52 24.4kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.09 1 r UNASSIGNED
logstash-2016.08.09 4 p STARTED 45 22.4kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.09 4 r UNASSIGNED
logstash-2016.08.12 4 p STARTED 565845 220.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.12 4 r UNASSIGNED
logstash-2016.08.12 0 p STARTED 565851 220.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.12 0 r UNASSIGNED
logstash-2016.08.12 3 p STARTED 565799 220.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.12 3 r UNASSIGNED
logstash-2016.08.12 1 p UNASSIGNED
logstash-2016.08.12 1 r UNASSIGNED
logstash-2016.08.12 2 p STARTED 566396 221.1mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.12 2 r UNASSIGNED
logstash-2016.08.13 2 p UNASSIGNED
logstash-2016.08.13 2 r UNASSIGNED
logstash-2016.08.13 0 p STARTED 7339 2.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.13 0 r UNASSIGNED
logstash-2016.08.13 3 p STARTED 7341 2.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.13 3 r UNASSIGNED
logstash-2016.08.13 1 p STARTED 7328 2.6mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.13 1 r UNASSIGNED
logstash-2016.08.13 4 p UNASSIGNED
logstash-2016.08.13 4 r UNASSIGNED
logstash-2016.08.14 2 p STARTED 5347 836.1kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.14 2 r UNASSIGNED
logstash-2016.08.14 0 p STARTED 5325 850.8kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.14 0 r UNASSIGNED
logstash-2016.08.14 3 p STARTED 5426 872.9kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.14 3 r UNASSIGNED
logstash-2016.08.14 1 p UNASSIGNED
logstash-2016.08.14 1 r UNASSIGNED
logstash-2016.08.14 4 p STARTED 5325 857.5kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.14 4 r UNASSIGNED
logstash-2016.08.15 2 p UNASSIGNED
logstash-2016.08.15 2 r UNASSIGNED
logstash-2016.08.15 0 p STARTED 5551 896.9kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.15 0 r UNASSIGNED
logstash-2016.08.15 3 p STARTED 5552 882.3kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.15 3 r UNASSIGNED
logstash-2016.08.15 1 p UNASSIGNED
logstash-2016.08.15 1 r UNASSIGNED
logstash-2016.08.15 4 p STARTED 5613 894.4kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.15 4 r UNASSIGNED
logstash-2016.08.16 2 p UNASSIGNED
logstash-2016.08.16 2 r UNASSIGNED
logstash-2016.08.16 0 p STARTED 4808 740.2kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.16 0 r UNASSIGNED
logstash-2016.08.16 3 p STARTED 4792 745.4kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.16 3 r UNASSIGNED
logstash-2016.08.16 1 p STARTED 4805 742.1kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.16 1 r UNASSIGNED
logstash-2016.08.16 4 p STARTED 4810 738kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.16 4 r UNASSIGNED
logstash-2016.08.17 4 p UNASSIGNED
logstash-2016.08.17 4 r UNASSIGNED
logstash-2016.08.17 0 p STARTED 4750 736.3kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.17 0 r UNASSIGNED
logstash-2016.08.17 3 p STARTED 4758 739kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.17 3 r UNASSIGNED
logstash-2016.08.17 1 p STARTED 4725 732.6kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.17 1 r UNASSIGNED
logstash-2016.08.17 2 p STARTED 4729 728.6kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.17 2 r UNASSIGNED
logstash-2016.08.18 2 p UNASSIGNED
logstash-2016.08.18 2 r UNASSIGNED
logstash-2016.08.18 0 p STARTED 4751 732.4kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.18 0 r UNASSIGNED
logstash-2016.08.18 3 p STARTED 4717 731kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.18 3 r UNASSIGNED
logstash-2016.08.18 1 p STARTED 4708 734.7kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.18 1 r UNASSIGNED
logstash-2016.08.18 4 p STARTED 4696 722.1kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.18 4 r UNASSIGNED
logstash-2016.08.19 2 p UNASSIGNED
logstash-2016.08.19 2 r UNASSIGNED
logstash-2016.08.19 0 p UNASSIGNED
logstash-2016.08.19 0 r UNASSIGNED
logstash-2016.08.19 3 p STARTED 4720 734.2kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.19 3 r UNASSIGNED
logstash-2016.08.19 1 p STARTED 4708 730.4kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.19 1 r UNASSIGNED
logstash-2016.08.19 4 p STARTED 4716 727kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.19 4 r UNASSIGNED
logstash-2016.08.30 2 p STARTED 803384 436.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.30 2 r UNASSIGNED
logstash-2016.08.30 0 p STARTED 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.30 0 r UNASSIGNED
logstash-2016.08.30 3 p UNASSIGNED
logstash-2016.08.30 3 r UNASSIGNED
logstash-2016.08.30 1 p STARTED 803545 437.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.30 1 r UNASSIGNED
logstash-2016.08.30 4 p STARTED 803369 436.7mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.30 4 r UNASSIGNED
logstash-2016.08.31 4 p STARTED 796090 434.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.31 4 r UNASSIGNED
logstash-2016.08.31 0 p UNASSIGNED
logstash-2016.08.31 0 r UNASSIGNED
logstash-2016.08.31 3 p STARTED 796163 433.5mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.31 3 r UNASSIGNED
logstash-2016.08.31 1 p STARTED 796216 434mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.31 1 r UNASSIGNED
logstash-2016.08.31 2 p STARTED 795518 433.3mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.31 2 r UNASSIGNED
kibana-int 4 p STARTED 0 144b 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
kibana-int 4 r UNASSIGNED
kibana-int 0 p STARTED 0 144b 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
kibana-int 0 r UNASSIGNED
kibana-int 3 p UNASSIGNED
kibana-int 3 r UNASSIGNED
kibana-int 1 p STARTED 1 12.4kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
kibana-int 1 r UNASSIGNED
kibana-int 2 p STARTED 2 22.1kb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
kibana-int 2 r UNASSIGNED
logstash-2016.08.10 4 p UNASSIGNED
logstash-2016.08.10 4 r UNASSIGNED
logstash-2016.08.10 0 p STARTED 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.10 0 r UNASSIGNED
logstash-2016.08.10 3 p UNASSIGNED
logstash-2016.08.10 3 r UNASSIGNED
logstash-2016.08.10 1 p UNASSIGNED
logstash-2016.08.10 1 r UNASSIGNED
logstash-2016.08.10 2 p STARTED 5332 1.1mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.10 2 r UNASSIGNED
logstash-2016.08.11 4 p STARTED 278771 107.3mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.11 4 r UNASSIGNED
logstash-2016.08.11 0 p STARTED 278411 107.1mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.11 0 r UNASSIGNED
logstash-2016.08.11 3 p UNASSIGNED
logstash-2016.08.11 3 r UNASSIGNED
logstash-2016.08.11 1 p STARTED 278588 107.4mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.11 1 r UNASSIGNED
logstash-2016.08.11 2 p STARTED 278941 107.1mb 10.2.8.74 ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
logstash-2016.08.11 2 r UNASSIGNED
[root@TGCS018 ~]#
"status" : "red",
[root@TGCS018 ~]#
results from
[root@TGCS018 ~]# nmap -sT -O localhost
Starting Nmap 6.40 ( http://nmap.org ) at 2016-09-20 19:52 EDT
RTTVAR has grown to over 2.3 seconds, decreasing to 2.0
Nmap scan report for localhost (127.0.0.1)
Host is up (0.000053s latency).
Other addresses for localhost (not scanned): 127.0.0.1
Not shown: 995 closed ports
PORT STATE SERVICE
22/tcp open ssh
25/tcp open smtp
80/tcp open http
5666/tcp open nrpe
9200/tcp open wap-wsp
No exact OS matches for host (If you know what OS is running on it, see http://nmap.org/submit/ ).
TCP/IP fingerprint:
OS:SCAN(V=6.40%E=4%D=9/20%OT=22%CT=1%CU=41826%PV=N%DS=0%DC=L%G=Y%TM=57E1CBD
OS:2%P=x86_64-redhat-linux-gnu)SEQ(SP=106%GCD=1%ISR=10D%TI=Z%CI=I%II=I%TS=A
OS:)OPS(O1=MFFD7ST11NW7%O2=MFFD7ST11NW7%O3=MFFD7NNT11NW7%O4=MFFD7ST11NW7%O5
OS:=MFFD7ST11NW7%O6=MFFD7ST11)WIN(W1=AAAA%W2=AAAA%W3=AAAA%W4=AAAA%W5=AAAA%W
OS:6=AAAA)ECN(R=Y%DF=Y%T=40%W=AAAA%O=MFFD7NNSNW7%CC=Y%Q=)T1(R=Y%DF=Y%T=40%S
OS:=O%A=S+%F=AS%RD=0%Q=)T2(R=N)T3(R=N)T4(R=Y%DF=Y%T=40%W=0%S=A%A=Z%F=R%O=%R
OS:D=0%Q=)T5(R=Y%DF=Y%T=40%W=0%S=Z%A=S+%F=AR%O=%RD=0%Q=)T6(R=Y%DF=Y%T=40%W=
OS:0%S=A%A=Z%F=R%O=%RD=0%Q=)T7(R=Y%DF=Y%T=40%W=0%S=Z%A=S+%F=AR%O=%RD=0%Q=)U
OS:1(R=Y%DF=N%T=40%IPL=164%UN=0%RIPL=G%RID=G%RIPCK=G%RUCK=G%RUD=G)IE(R=Y%DF
OS:I=N%T=40%CD=S)
Network Distance: 0 hops
OS detection performed. Please report any incorrect results at http://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 13.16 seconds
PORT STATE SERVICE
22/tcp open ssh
25/tcp open smtp
80/tcp open http
5666/tcp open nrpe
TCP/IP fingerprint:
OS:I=N%T=40%CD=S)
- Box293
- Too Basu
The UNASSIGNED primary (p) shards are the root of your problem. More specifically the nagioslogserver and kibana-int need to be re-assigned.
This KB article explains how to re-assign them.
https://support.nagios.com/kb/article.p ... ategory=42
All of a sudden it is now giving me the logon screen but now getting this error
Could not get user. Specified ID may be wrong.
Troy
I ran this
[root@TGCS018 /]# curl -s -XGET http://localhost:9200/_cat/shards?v | egrep 'UNASSIGNED|INITIALIZING'
[root@TGCS018 /]#
From your link
Re-assignment command:
curl -XPOST 'localhost:9200/_cluster/reroute' -d '{ "commands" : [ { "allocate" : { "index" : "indexnamehere", "shard" : shardnumberhere, "node" : "nodenamehere", "allow_primary" : true } } ] }'
Using the screenshot above, here is a full example:
curl -XPOST 'localhost:9200/_cluster/reroute' -d '{ "commands" : [ { "allocate" : { "index" : "nagioslogserver_log", "shard" : 2, "node" : "54bc3e7e-7478-4f28-bfa7-5020f6fbf0ae", "allow_primary" : true } } ] }'
My command would be this
curl -XPOST 'localhost:9200/_cluster/reroute' -d '{ "commands" : [ { "allocate" : { "index" : "nagioslogserver", "shard" : 2, "node" : "???????????????????????????????????????????????????????", "allow_primary" : true } } ] }'
curl -XPOST 'localhost:9200/_cluster/reroute' -d '{ "commands" : [ { "allocate" : { "index" : "nagioslogserver_log", "shard" : 2, "node" : "??????????????????????????????????????????????", "allow_primary" : true } } ] }'
curl -XPOST 'localhost:9200/_cluster/reroute' -d '{ "commands" : [ { "allocate" : { "index" : "kibana-int", "shard" : 2, "node" : "?????????????????????????????????????????????????????????", "allow_primary" : true } } ] }'
1. What do I put for the node?
2. What about logstash?
I ran this
[root@TGCS018 /]#
From your link
